Issue with bumps and normal maps on a single UVmap model...
Posted: Thu Nov 02, 2017 10:28 pm
by Tigersan
This is a game model, so everything is on a one texture. UV area corresponding to legs and arms
is cloned, so whatever changes you make in the arm/leg are gets applied to both on the model...
Problem I got is the left arm and leg look weird, kinda as if the bump/normal were inverted but
only in that area... See for yourself in the picture i attached. It doesnt matter wether its a normal
map, or B&W bump map... I got both. Its weird because the diffuse texture looks perfectly fine...
*Shrugs*
Any idea how to get around this?
Re: Issue with bumps and normal maps on a single UVmap model...
Posted: Thu Nov 02, 2017 10:54 pm
by face_off
I cannot see any reason why this is happening. To investigate, I would suggest turning on all the Render Passes, and check each one for clues.
Posted: Fri Nov 03, 2017 5:17 am
by Tigersan
I decided to just use displacement map, it works fine, i dont have time to spend a whole day figuring out
what causes it... Thanks for the suggestions though! :)
