				Daz 4.10 - Anything Game Changing for You?
				Posted: Wed Nov 01, 2017 1:47 pm
				by Notiusweb
				I'm wondering if anyone has found anything truly improved about working with the 4.10 update.
I see within Daz the ability to use the morph targets on the face in PowerPose Tab for expressions on the newer characters, I like that.
Buy Iray still feels as Low Octane as ever, and not much else seems different.
Any new abilities strike thine fancy?
				Re: Daz 4.10 - Anything Game Changing for You?
				Posted: Wed Nov 01, 2017 4:10 pm
				by DrHemulen
				Yeah, the clothes simulation seems incredible. I've been trying to get that to work on Blender. It's slow, tedious and error-prone. In DAZ 4.10 it seems like magic. Even uses GPU acceleration, so it's very fast too. Seems to work with almost all clothing too.
				Posted: Wed Nov 01, 2017 5:20 pm
				by birdovous
				DrHemulen wrote:Seems to work with almost all clothing too.
Isn't it supposed to work only with clothes that are designed to be used with it (with the 'dForce' mentioned in the description)?
				Posted: Wed Nov 01, 2017 6:48 pm
				by DrHemulen
				That was my initial thought as well, but after seeing other people posting about it, I tried it on an old item of clothing, and it worked perfectly fine.
i think that if it has the nForce tag, it's veryfied to work, and the parameters are tweaked to fit the product.
				Posted: Mon Dec 04, 2017 5:04 am
				by larsmidnatt
				the cloth sim is very slow, not good and never works for me. The acceleration is a lie, at least from my experience. I don't have any Dforce enabled cloth though.
I'll stick to MD for now.
				Posted: Wed Dec 06, 2017 8:37 am
				by TRRazor
				I simulate non-dForced-tagged clothing all the time.
The trick is to lower the Bend Stiffness node from its default value 0.5 to something around 0.4 or 0.3 that makes most clothing work just fine with dForce.
Also switch the collision method for simulating clothing to "Good - Discrete Swept Vertex".
Converting the clothing to SubD also helped wonders for me.
Try a combination of the above and it should work fine for you as well.
Stay clear of flimsy stuff like underwear though, as that will most likely still explode during simulation as it doesn't contain enough geometry.
				Posted: Wed Dec 06, 2017 7:50 pm
				by larsmidnatt
thanks for the tips. that did help a little bit.
				Posted: Thu Dec 07, 2017 1:47 pm
				by DrHemulen
				Dumb question: Where do I find those nodes (bend stifness and so on)?
 I can find very limited options in the Simulation pane and under Parameters for the clothing item.
				Posted: Sat Dec 09, 2017 8:08 am
				by TRRazor
				You can find them in the clothing items corresponding surfaces. (Surface tab in DS).
