Environment Tag HDR issue
Posted: Sat Oct 21, 2017 9:29 pm
by thanulee
Hi, I am testing some of my HDR collection and i see that i dont get the expected results. I get really bright areas and no consistency on how hdr was supposed to light the scene.
If i uncheck importance sampling, it gives me a very dull result and if its on a very bright. I have to lower the hdr power to values like 0.001 in order to avoid overbright areas and still the light doesnt correspond to the environment. I got a very dark env and a whatever light that just doesnt burn out everything. Im using 3.07.0 test6a as im testing this.
I have tested the same hdrs many times in Vray and in production with no problems.
I attach a scene and some images to demonstrate the issue cause idk if i describe it correct. This thing happens with the majority of my hdrs btw.
scene: https://www.dropbox.com/s/02wam0oshdty3 ... e.c4d?dl=0
hdr: https://www.dropbox.com/s/1s1vcaiwdhybn ... M.hdr?dl=0
Re: Environment Tag HDR issue
Posted: Sun Oct 22, 2017 12:49 am
by aoktar
Find gamma of imagetexture and play wit it.
Posted: Sun Oct 22, 2017 10:05 am
by thanulee
Cool, thanks, changing it to linear seems to load the hdr correct. There was a more obvious switch with gamma if i remember correctly, its been replaced with this menu?
Another question though, why when i change the settings there, hdr doesnt get affected? see images
Cheers!
Posted: Sun Oct 22, 2017 12:01 pm
by aoktar
You're using that wrong! Why don't you use ImageTexture, not XBitmap?
Posted: Sun Oct 22, 2017 12:10 pm
by thanulee
Mmmm what do i do wrong? I am adding an octane hdr sky and i load the texture in there. Is there another way?
Posted: Sun Oct 22, 2017 12:13 pm
by thanulee
Oh ok i figured that out. I m using HDR link from GSG and it doesnt work as expected and replaces the image texture. I should just re add it manually!
Thanks for the help!
Posted: Sun Oct 22, 2017 5:27 pm
by niestudio
HDRI Link works great when setup properly, here is the setup for octane
Posted: Sun Oct 22, 2017 5:39 pm
by thanulee
For some reason doesnt let me drag it to "file" and only to "texture". Idk why is that. Thanks for the help anyways.
