Export BatchRender Plugin (publishing set) to Standalone
Posted: Sat Oct 21, 2017 11:19 am
Hi Guys, especially Paul
I was wondering if you ArchiCAD users use the Batchrendering?
Do you use it a lot, how do you use it.. and maybe you can share your experience and wishes here.
I am using the ArchiCAD BatchRendering quit a lot using the AC Publisher Set,
having the same target name for all cameras...
It works fine.
Example of how you see here: download/file.php?id=21315&mode=view)
But now I was wondering if I could export it to the OctaneRender standalone.. when exporting the scene to orbx/ocs I only have one camera exported, right?
So might there be a way to exsport from plugin/ArchiCAD to the standlone with multiple cameras and have a simple to use BatchRender in the standlone as well?
The best thing would be exporting the AC publish set to an orbx file and a BatchRender file as well for all the cameras to use in the Standalone by importing it using Lua Scripting.
@Paul, do you see any possibility here? Maybe for the plugin.. or for someone else to write something for the Lua Scripting.. or otherwise?
greetz,
It works fine.
greetz,
