Trouble HDRI with Render passes / compositing
Posted: Sun Sep 03, 2017 4:50 am
by adamfilip
Trying to figure out the render layer system while using HDRI environment and catching shadows/reflections
preview
preview
can the shadow pass already have transparency on it.
I really just want it to out put 4 layers. background environment, reflection with transparentcy, shadow with transparency and foreground with transparency. is this possible
I would rather not even have to output render layers and just end up with a final rendered beauty pass with it all composited and done. but the matte object is not working for me.
I have attached my test scene. if anyone can help me get this setup. please
Desktop.zip
test scene
(9.54 MiB) Downloaded 280 times
Re: Trouble HDRI with Render passes / compositing
Posted: Sun Sep 03, 2017 6:38 pm
by niestudio
Check out this video tutorial for Render layer system
https://vimeo.com/119848103
Posted: Mon Sep 04, 2017 2:32 pm
by bepeg4d
Hi adamfilip,
I have roughly corrected your scene:
Desktop.zip
(16.17 MiB) Downloaded 390 times
First of all, use the object tag with Object Layer ID 2 onto the Sphere, this is your primary object and the center of your interest. Note that by default all the other geometry objects are on Layer 1. Then use a glossy material with a color similar at what is surrounding on a bigger plane:
Then enable the Environment pass in Beauty passes, and the Black shadow and reflection pass in the Render Layer passes, finally turns on the Alpha channel in kernel:
Then in Photoshop, you need only to move the Environment pass at the bottom, and change the Reflection pass to Linear Add:
ciao beppe
