Calling "Render" from Editor script
Moderator: ChrisHekman
ChrisHekman
The script that jalley posted should work. It just misses the following function:
OctaneUnity.Scene.Instance.UpdateScene()
This has recently been exposed and should update any changes made to the unity scene.
If you want to automatically start rendering from C# you can do the following:
OctaneUnity.Scene.Instance.RenderTarget = m_MyRenderTargetComponent.RenderTarget;
*If you want to drive everything from code, you will need to update the scene after setting the rendertarget
jalley
Dear Octane Team,
I am now a licensed customer, unfortunately I can not post a new topic in any forum, so I am using the most related open question I did in the past.
Let me briefly summarize the problem we are facing. We use the Octane Studio edition. The thing is when rendering in batch using a script, Octane complains with the following message:
"Received result with higher change level than our current render change level. This should never happen unless someone else fiddled around with the render target."
But we are rendering always with render targets that have the same rendering configuration, including the amount of samples per pixel. From time to time we change the HDR image used to illuminate, but everything else is the same.
So, could you let us know how we could prevent those errors and messages to block our script. Basically we load a scene contianing several .orbx files, render it and then load another scene, etc.
Sometimes in the past it worked for several scenes consecutively, but recently only one scene per script call is rendered.
Thank you.
PS. How can I post a new message in the customers forums? Thank you.
Return to “Unity”
