ORBX export to standalone - Update Geometry
Posted: Sat Aug 19, 2017 11:39 pm
by newmountain
Hello, What is the best way to update geometry after exporting an initial ORBX file from REVIT to Octane Standalone?
Say you have spent some time developing a scene in Standalone, and the REVIT design changes.
Instead of starting over with a new ORBX export from REVIT, I just want to update the geometry / REVIT mesh.
Thanks! Jason
Re: ORBX export to standalone - Update Geometry
Posted: Tue Aug 22, 2017 12:27 am
by newmountain
Hello, I was able to update REVIT geometry in Standalone by exporting a new ORBX, then copy and pasting the new mesh into the original scene file.
Just had to re-pipe the material nodes. Is this the suggested way to update revit geometry in standalone or is their an obvious and automatic way I am overlooking?
Also are there any import / export units to be considered when exporting to standalone, or is this automatic? I work in inches in REVIT and have to scale up material sizes dramatically in standalone.
And, are there differences between exporting to ORBX vs OCS?
Thank You! Jason
Posted: Tue Aug 22, 2017 1:23 am
by face_off
Yes, this is the best way. There is probably saome LUA code you could write to automatically plugin in the materials (check the LUA forum here - it may have already been written).
OctaneRender for Revit will convert the scene into meters when loading into Octane. This should also happen when exporting to OCS/ORBX.
ORBX is like a zip file containing the .OCS file and all the scene assets (texturemaps, obj files, etc).
