Problems with VRAM
Posted: Mon Jul 03, 2017 7:23 pm
by 312112_80
Is possibly get a solution without buy a new GPU. VRAM Assignment by BIOS?
Re: Problems with VRAM
Posted: Mon Jul 03, 2017 11:44 pm
by face_off
Hi - that error is saying you have run out of memory on your card. You have detailed which card you are running, or how much memory it has, so it's hard for me to provide a solution.
Posted: Tue Jul 04, 2017 2:06 am
by 312112_80
Ok thanks, these are the specs
Graphics Processor Properties
Video Adapter EVGA e-GeForce GTX 680
BIOS Version 80.04.09.00.80
BIOS Date 3/13/2012
GPU Code Name GK104
PCI Device 10DE-1180 / 3842-2680 (Rev A2)
Transistors 3540 million
Process Technology 28 nm
Die Size 294 mm2
Bus Type PCI Express 2.0 x16 @ 2.0 x16
Memory Size 2 GB
GPU Clock 1005 MHz
RAMDAC Clock 400 MHz
Pixel Pipelines 32
Texture Mapping Units 128
Unified Shaders 1536 (v5.0)
DirectX Hardware Support DirectX v11
WDDM Version Unknown (ID = 2200)
Posted: Tue Jul 04, 2017 2:17 am
by face_off
You have 2GB of RAM on your graphics card - which is not enough. Windows will take nearly half that, and Rhino will take a lot for it's OpenGL display, leaving almost no RAM for Octane. If you have a second card, you could use that for your display adapter, which will free up the space Windows and Rhino are using. You can also enable Out Of Core Textures in the OctaneRender for Rhino plugin so texturemaps are stored in CPU RAM rather than GPU RAM. But 2GB is just not enough for anything serious.
Posted: Tue Jul 04, 2017 2:53 am
by 312112_80
Okay, I understand, I'll have to buy a second card then. how to enable out of core textures?
Posted: Tue Jul 04, 2017 3:14 am
by face_off
It's in the Devices tab.
Posted: Fri Jul 07, 2017 4:04 am
by 312112_80
Ok, I already bought another GPU. A GTX1080TI 11GB. Obviously an SLI is not possible. But there will be some way for Octane to recognize both cards for the calculation and not just the list of devices; So the error still comes out for the old card.
thanks
Posted: Fri Jul 07, 2017 11:08 am
by face_off
The amount of VRAM available to Octane will be that of the LOWEST RAM card - so disable the card with 2GB RAM in the Devices tab in order to use all the available VRAM of the GTX 1080TI .
Posted: Sun Jul 09, 2017 12:26 am
by 312112_80
It was possible to work together with the old GPU, connect the main display to the new card, now Octane starts the calculation for the new GPU and not the old one.
