Alpha Material issue
Posted: Sun May 14, 2017 6:17 am
by hoice
I've been trying to apply an Alpha layer to an object with another object that has a displacement map on it. When i do this the transparent alpha material with a pattern on it becomes solid again. EX:
Material A) Transparent Alpha with Pattern
Material B) Displacement Material
Alpha layer becomes solid when both are applied to object... Ie. i cant see the displacement through the alpha layer.
Any help? Thanks
Re: Alpha Material issue
Posted: Sun May 14, 2017 6:31 pm
by hoice
Made some progress... i've gotten the bump layer to work but still cant get displacement. Maybe this cant even be done now that i think of it...
Posted: Mon May 15, 2017 3:41 am
by itsallgoode9
I do alot of work with stuff like this but i don't quite understand what is happening. can you post some photos?
Posted: Thu May 25, 2017 2:59 am
by hoice
itsallgoode9 wrote: itsallgoode9
Hey i got it working - check it out - thanks for the help tho
Posted: Thu May 25, 2017 4:19 am
by itsallgoode9
what was causing your issue? just so I know, should I ever run into an issue.
Posted: Thu May 25, 2017 2:47 pm
by hoice
itsallgoode9 wrote:what was causing your issue? just so I know, should I ever run into an issue.
To be honest I just kept messing around - rebooted, tried different materials till it worked. Kinda sketchy.
