Glass in directlight
Posted: Fri Apr 01, 2011 12:48 pm
by thiagobulhoes
hi, wonder if you could not delete the AO glass, because the glass at first does not generate a shadow.
This would enable to expand the use of AO inanimations projects, where the pathtracing is still very slow.
Re: Glass in directlight
Posted: Mon Apr 04, 2011 11:50 pm
by radiance
The issue here is that rays that pass through the glass, if the area behind it is ocluded, cannot find any indirect light as they are locked inside the object behind it.
This requires a few major changes to the kernel that will make it quite slow, and might make the directlighting kernel much slower for what it was meant for, previewing fast.
Maybe we will add this in the future, or as a specialized kernel for animations.
Radiance
Posted: Tue Apr 05, 2011 5:27 am
by thiagobulhoes
ok, thanks.
Posted: Tue Apr 05, 2011 12:18 pm
by arexma
Specialized kernel for animations *drools*
Where do I pay for the next development stage?
You need more coffee? I can send you a sack!
Posted: Sat Apr 09, 2011 10:47 pm
by Refracty
Having light passing through transparent objects with direct lighting would be very, very useful.
Very often there are only a few minutes for rendering left and path tracing is nice but still takes some time.
Please add this feature / option. Its useful not only for animations.
Posted: Sat Apr 09, 2011 10:54 pm
by necko77
+1
Posted: Tue Apr 12, 2011 10:37 pm
by vinz
+2
Posted: Wed Apr 13, 2011 6:04 am
by bepeg4d
+100
maybe an "AO-off" node to put between a node material and the mash-node
ciao beppe
Posted: Wed Apr 13, 2011 11:50 am
by tungee
Nk-metal fresnel-node.
and some more procedural noises..
