Shadow pass
Posted: Thu Mar 30, 2017 11:15 am
by ramone163
I have scene with Sun Light, and I want to save object+shadow on transparency background.
How to render clean shadow without AO?
Re: Shadow pass
Posted: Thu Mar 30, 2017 12:23 pm
by paride4331
Hi ramone163,
you have to use "alpha channel" Kernel setting and "shadow catcher" for cast shadows (in spread material).
About those concentric circles, check your scale units and the value of epsilon-ray.
The ray epsilon is the distance to offset new rays so they do not intersect with the originating_server geometry.
If the scale of your scene is too large, precision artifacts in the form of concentric circles may appear.
In That case, Increasing the ray can make epsilon These artifacts disappear.
In general, using high density meshes, the default "Ray Epsilon" of 0001 can be used. E.g. A "rayepsilon" of 0075 = 7.5cms.
Re: Shadow pass
Posted: Thu Mar 30, 2017 12:33 pm
by ramone163
"alpha channel" + "shadow catcher"
Re: Shadow pass
Posted: Thu Mar 30, 2017 1:21 pm
by paride4331
Hi ramone163,
there may be a minimum of gray with AO 0.01 but your seems too much.
have you turned off the vignetting?
Re: Shadow pass
Posted: Thu Mar 30, 2017 1:40 pm
by ramone163
Vignetting is OFF.
How to make AO 0.0?
And why AO in SHADOW pass also?
paride4331 wrote:Hi ramone163,
Re: Shadow pass
Posted: Thu Mar 30, 2017 1:58 pm
by paride4331
Hi ramone163,
0,01 is max in 3dsMax plugin and in Octane SA is 0 but this issue is like 0,01.
This issue you would have with shadow and black shadow pass too.
Perhaps new shadow pass (Octane SDK 3.06 Test 4) could solve it, but 3dsMax plugin is 4.30 - 3.05 now, and 4.31 - 3.06 (TEST) is SDK Test 3.
Re: Shadow pass
Posted: Thu Mar 30, 2017 2:23 pm
by ramone163
In Octane SA 3.06 Test 4 new shadow pass works fine, but not in 3ds max.
Hope they fix it.
