Octane Scatter Alignment
Posted: Wed Mar 08, 2017 6:37 pm
by dh921911
Hey guys,
Im trying to distribute several objects onto a plane with Octane scatter, but I can't get them to align properly on the surface. I need them to rotate up 90 degrees so they aren't laying down. With a Mograph cloner I would go over to the transform tab and make the adjustment easily.
I see the Position, Scale, Rotate parameters at the bottom of the distribution menu, but only the X value seems to change their orientation, and not in the direction I need.
I attached the scene file. Could someone take a look? Hopefully im missing something easy.
https://www.dropbox.com/s/3auv6drzve588 ... 1.c4d?dl=0
Re: Octane Scatter Alignment
Posted: Wed Mar 08, 2017 9:32 pm
by toto79
Posted: Thu Apr 27, 2017 9:18 am
by chrisbrearley
Any chance you can explain how you did this Toto? I'm coming up against the same issue, I've copied settings from the scene you uploaded but I still can't get my clones to rotate upwards.
Posted: Thu Apr 27, 2017 6:48 pm
by toto79
You can change the object by rotating it on the point level to face the Y up direction or change the up vector to 180 on the scatter object.
