every first frame renders too bright
Posted: Wed Feb 22, 2017 1:31 pm
by miohn
have a big problem here (Version 3.05.1)!
I've set up an animation with serveral products on a turntable.
Whatever framerange I choose, every time the "first" frame renders too bright.
If I render from frame 100 to 300 = frame 100 is too bright
When I render from 250 to 550 = frame 250 is too bright
How can this happen?
Its not a big problem as long as I render the hole sequence on my mashines,
but when rendering on a farm, means, that f.e. every 5th frame is too bright and I have
light flickers during the entire animation.
Haven't recognized this behavior before.
Any idear whats going on?
Mike
Re: every first frame renders too bright
Posted: Wed Feb 22, 2017 1:50 pm
by bepeg4d
Hi Mike,
very weird and annoying issue.
It would be great if you could share a scene :roll:
ciao beppe
Posted: Wed Feb 22, 2017 1:51 pm
by aoktar
You know what i say. Scene please!!!
Posted: Wed Feb 22, 2017 2:27 pm
by miohn
cannot send the scene, because its too big and a ongoing project.
Maybe I'll try to extract parts, but this will take a while
regards
Mike
Posted: Wed Feb 22, 2017 8:25 pm
by miohn
Hi Ahmet,
here is a testfile.
Alsoe here, every first frame is brighter.
Test_first_frame_always_brighter.zip
(1.02 MiB) Downloaded 215 times
Maybe you can check, whats wrong here.
I have no idear.
thanks
Mike
Posted: Wed Feb 22, 2017 9:54 pm
by aoktar
Thanks! There's a bug as i can see. It's working fine if i copy to new scene and render. I'm looking for main reason.
Posted: Wed Feb 22, 2017 11:38 pm
by aoktar
I think i found the problem. First is that i need to know is it an old scene? Because there's a problem on deprecated parameter of octane render settings. Plugin refer to this deprecated parameter and calculate wrong structures. For example if you create new render settings and select "OctaneRender" it will be fixed.
Posted: Thu Feb 23, 2017 12:55 am
by miohn
Hi Ahmet,
it is in fact based on an older Scene.
Copying to a new Scene (this time I forgot that
workaround which I normally try first)
fixed it already.
Thanks much!
regards
Mike
Posted: Fri Jun 26, 2020 11:51 pm
by jessestormer
I also just bumped into this issue with Octane 2020.1 - Thank you for providing your solution here!!
