Octane bad geometry
Posted: Thu Feb 09, 2017 7:54 pm
by Tharso
Hi !!
Can you tell me why this happen?
Re: Octane bad geometry
Posted: Thu Feb 09, 2017 8:17 pm
by itsallgoode9
it's probably the weird way you have the geo at the corner of your chambers. you prob need to connect those edges somewhere.
Posted: Thu Feb 09, 2017 9:32 pm
by Renart
Yeah I guess Octane doesn't like faces with more than 4 edges. You can quickly triangulate to see or add some split
Posted: Thu Feb 09, 2017 9:44 pm
by itsallgoode9
It's not that it doesn't like more than 4 edges, it's those weird triangles around the chamfers next to the concave shapes. That some extremely peculiar geometry.
Posted: Thu Feb 09, 2017 11:34 pm
by Tharso
I know if I connect the edges and fix the geometry will work, but I had hope that it could be fix with another way, because other renderers works fine with this geometry.
Thanks !!
Posted: Fri Feb 10, 2017 6:23 am
by calus
Precisely, Octane core doesn't tesselate correctly concave n-gon.
You don't have another choice than pre-dividing your geometry in Maya.
Despite the years of development, some parts of the Maya plugin are still early implementation ...
In fact we should have the option in the plugin UI to be able to use Maya tesselation or not for every shape,
All other Maya renderers support this feature...
Furthermore this would give us out of the box support for every Maya geometry type (nurbs, precalculated smooth preview, ...).
And for example, this is what the Modo Octane plugin do, using Modo own tesselation.
Posted: Fri Feb 10, 2017 1:43 pm
by Tharso
calus wrote:Precisely, Octane core doesn't tesselate correctly concave n-gon.
good ! We need that !
