OctaneRender® for Maya® 3.05.3 - 9.31 [OBSOLETE]
Posted: Fri Jan 27, 2017 12:18 am
by JimStar
Otoy® is proud to announce the availability of a new version of OctaneRender™ for Maya®
Maya® Version Requirements
This release will work with Maya® Versions 2015, 2016, 2016.5 and 2017 64-bit on MS Windows operating systems, 2015, 2016, 2016.5 and 2017 64-bit on Linux operating systems, and 2016, 2016.5 and 2017 64-bit on OSX operating systems (including and above 10.9).
To run OctaneRender™ for Maya®, you need to also have an activated OctaneRender™ Standalone copy activated on the machine you wish to install the plugin onto.
You cannot purchase and use only the Maya plugin and use it without also owning an activated copy of Octan eRender™ Standalone on your machine.
For network slave and daemon please download standalone installer here:
viewtopic.php?f=24&t=58640
CHANGES SINCE THE PREVIOUS VERSION
  • Improved gradient nodes to not assume the first non-existing color-array element (lost in previous versions after saving) to always be black. It will still be assumed black when opening the previous versions scenes, and converted automatically to an explicit black first color element (which now will not be lost after saving). Now gradient nodes are resistant to screwing up position values of different elements.
  • + One more quick-fix: messing with position values when IPR is active is more robust now.
  • Minor fixes and improvements...
Windows
DOWNLOAD
OctaneRender for Maya 9.31
OctaneRender for Maya DEMO 9.31
Linux
Installation:
- Just run the installer to see its command line keys.
DOWNLOAD
OctaneRender for Maya - 9.31 Linux
OctaneRender for Maya DEMO - 9.31 Linux
OSX
Installation:
- Just run the autoinstaller file.
DOWNLOAD
OctaneRender for Maya - 9.31 OSX
OctaneRender for Maya DEMO - 9.31 OSX
