Bug: Missing tabs in Attributes Panel
Posted: Sun Jan 22, 2017 2:16 pm
by jjmotionstudio
I just recently installed 3.04.5-R2, and noticed that the emission, common, normal, and transmission tabs are missing from the Attributes panel when adjusting materials. It still shows up in the Material editor, so I'm guessing its a bug in the latest version. It looks almost like the tabs for the Specular material got mixed up with the tabs for the Diffuse. Just thought I'd mention it!
Here's what I mean:
Re: Bug: Missing tabs in Attributes Panel
Posted: Sun Jan 22, 2017 2:38 pm
by aoktar
I don't think that's a BUG. Because it's just about RES folder content. This interface is built by some files in RES folder.
Why don't you check this installlation: viewtopic.php?f=85&t=58047
Posted: Sun Jan 22, 2017 3:01 pm
by jjmotionstudio
Since that's an SDK (not full release), we'd prefer to stay on the most recent stable version for now.
I'm unsure what "RES" means - could you explain? Is there a way to fix it?
Posted: Sun Jan 22, 2017 3:07 pm
by jjmotionstudio
Also, I just deleted my preferences folder to reset everything, and the tabs are still missing from the attributes panel.
How is this not a bug? If it's something that is wrong with the plugin, and you have to find a workaround, it's a bug.
Posted: Sun Jan 22, 2017 3:14 pm
by jjmotionstudio
Here's a video of me walking through the issue. Let me know if this is fixed in the most recent SDK:
https://www.dropbox.com/s/hmy7644tg1jkx ... t.mov?dl=0
Posted: Sun Jan 22, 2017 3:37 pm
by aoktar
Please give a test with 3.05.3 as i say. It's latest stable.
RES is folder under c4doctane which contains all resource files.
Posted: Tue Jan 24, 2017 8:02 pm
by jjmotionstudio
@Aoktar -
Since we have 3.04.5-R2 installed across 6 machines that are networked together, updating to the latest SDK would require me to do that to all the machines. Also, after reading the update notes in the link you sent me, it doesn't mention that this issue is fixed in the latest release. Can you confirm that this is fixed in the SDK you shared?
JJ
Posted: Tue Jan 24, 2017 9:04 pm
by aoktar
I can't confirm or uncorfim. It's not a issue on me. As i said that's not about plugin codes or SDK. It's most likely about missing/wrong external files in RES. I can't know without help of users.
