Transform Node Slider/ Projection Proxy
Posted: Mon Jan 16, 2017 4:55 pm
by Renart
Hi!
- Is it possible to have sliders in the transform nodes instead of text boxes where you have to put the values yourself ? Or maybe there is a way to change it?
Using the channel box click and drag is not very handful.
- Same with the Projection node. If there is a way to have a proxy representation of the projection in the scene it would be very usefull ! Something that we can transform, rotate and scale to affect the projection node's transformation.
Thank you!
Re: Transform Node Slider/ Projection Proxy
Posted: Mon Jan 16, 2017 8:55 pm
by calus
Renart wrote:Hi!
If you don't like dragging attributes with the channel box,
Crtl Drag in the attribute editor field do the same.
But it's even more handy as you can have 3 speed of virtual cursor :
Ctrl Left Mouse Button drag: slow cursor
Ctrl Middle Mouse Button drag: normal cursor
Ctrl Right Mouse Button drag: fast cursor
Also you can just connect the Translate, Rotate, Scale attribute of a Maya Locator node to the Octane Transform node,
to manipulate it directly in the viewport:
(If you use "Local coordinate space" in the project node, you must parent the locator to the object)
Posted: Tue Jan 17, 2017 2:03 pm
by Renart
Thank you Calus!
I didn't know you can drag the values on the attribute editor as well
For the projection, it's a good idea!
I made a quick and dirty script to make the process more easy everytime :
import maya.cmds as cmds
#Octane_Projection_Setup
#Select the texture node to project and run the script. It will create a locator linked to the projection to make the transform more easy to manipulate.
#You can change the projection type by changing the octaneBoxProjection with what you need
#Nodes creations
TextureNode = cmds.ls(sl=1)
NameSuffix = TextureNode[0]
ProjectionNode = cmds.createNode('octaneBoxProjection', n='octaneBoxProjection_'+NameSuffix)
TransformNode = cmds.createNode('octaneTransform3D', n='octaneTransform3D_'+NameSuffix)
ConversionNode = cmds.createNode('unitConversion', n='unitConversion_'+NameSuffix)
LocatorNode = cmds.spaceLocator(n='Locator_'+NameSuffix)
#Connections
cmds.connectAttr('Locator_'+NameSuffix+'.rotate','unitConversion_'+NameSuffix+'.input')
cmds.connectAttr('unitConversion_'+NameSuffix+'.output','octaneTransform3D_'+NameSuffix+'.Rotation')
cmds.connectAttr('Locator_'+NameSuffix+'.scale','octaneTransform3D_'+NameSuffix+'.Scale')
cmds.connectAttr('Locator_'+NameSuffix+'.translate','octaneTransform3D_'+NameSuffix+'.Translation')
cmds.connectAttr('octaneTransform3D_'+NameSuffix+'.outTransform','octaneBoxProjection_'+NameSuffix+'.Transform')
cmds.connectAttr('octaneBoxProjection_'+NameSuffix+'.outProj',NameSuffix+'.Projection')
#SetAttributes
cmds.setAttr('unitConversion_'+NameSuffix+'.conversionFactor',57.296)
I'm gonna create a thread in the tutorial folder as well
Cheers!
