Setting lights color from color palette
Posted: Fri Jan 13, 2017 8:42 am
by FahadA92
Hello,
I have a color palette that I'd like to use to light my scene. I've tried all methods, and it seems the only way to set color in octane is with temperature but I only have the rgb values from Houdini (see attachment). I even tried changing the diffuse color in the emission material but that didn't help.
Re: Setting lights color from color palette
Posted: Fri Jan 13, 2017 9:01 am
by juanjgon
If you are lighting your scene using objects with the Octane OBJ spare parameters, you only need to set the Emission type to "Color/Texture" and set the color using the Color RGB parameter. The same happens if you are using a custom emission material, you must use the Texture Emission node.
Posted: Fri Jan 13, 2017 4:30 pm
by FahadA92
Thank you prompt reply. I used the Octane OBJ spare parameters, and it worked! I don't know why it didn't before, or how I missed it.
Thank you again.
