Page 1 of 2
OctaneRender® for Maya® 3.05.2 - 9.19 [OBSOLETE]
Posted: Sun Jan 08, 2017 9:57 pm
by JimStar
Otoy® is proud to announce the availability of a new version of OctaneRender™ for Maya®
Maya® Version Requirements
This release will work with Maya® Versions 2015, 2016, 2016.5 and 2017 64-bit on MS Windows operating systems, 2017 64-bit on Linux operating systems, and 2017 64-bit on OSX operating systems (including and above 10.9).
To run OctaneRender™ for Maya®, you need to also have an activated OctaneRender™ Standalone copy activated on the machine you wish to install the plugin onto.
You cannot purchase and use only the Maya plugin and use it without also owning an activated copy of Octan eRender™ Standalone on your machine.
For network slave and daemon please download standalone installer here:
viewtopic.php?f=24&t=58323
CHANGES SINCE THE PREVIOUS VERSION
  • Fixed single image rendering bug.
Windows
DOWNLOAD
OctaneRender for Maya 9.19
OctaneRender for Maya DEMO 9.19
Linux
Installation:
- Just run the installer to see its command line keys.
DOWNLOAD
OctaneRender for Maya - 9.19 Linux
OctaneRender for Maya DEMO - 9.19 Linux
OSX
Installation:
- Just run the autoinstaller file.
DOWNLOAD
OctaneRender for Maya - 9.19 OSX
OctaneRender for Maya DEMO - 9.19 OSX
Re: OctaneRender® for Maya® 3.05.2 - 9.19 [STABLE]
Posted: Mon Jan 09, 2017 10:08 am
by calus
In addition, I noticed 2 other bugs fixed in this release :) (maybe fixed in 9.17 or 9.18):
- Batch-render now works when there is a dot in the File Name Prefix (typical when using "increment&save")
- Batch-render now works when File Name Prefix path contains multiple sub-directory
Posted: Mon Jan 09, 2017 10:44 am
by renmaxhb
light fog cannot work with a matte object ,this is a bug?
v2 works well ;)
Posted: Mon Jan 09, 2017 11:05 am
by calus
renmaxhb wrote:light fog cannot work with a matte object ,this is a bug?
v2 works well ;)
I'm not sure what you want to achieve exactly in this scene ?
I guess maybe your problem comes from the difference between V2 and V3 scattering medium,
as there is a "inverse absorption" attribute in V3 enabled by default, you might have an inverted absorption compared to V2 ?
If this is is the problem, you just need to change absorption from 1 to 0, or disable the "invert absorption" checkbox.
Posted: Tue Jan 10, 2017 3:08 am
by renmaxhb
I know this about Invert Abs,I found matte poly has no shadow at Kernel alpha shadow,this is why light fog no shadow effect ;)
by renmaxhb
I know this about Invert Abs,I found matte poly has no shadow at Kernel alpha shadow,this is why light fog no shadow effect ,so it is a bug ;)
Posted: Tue Jan 10, 2017 3:46 am
by vfxm
Thanks for the updates , now we want Octane volume in maya to read .vdb files
Posted: Tue Jan 10, 2017 4:51 am
by calus
renmaxhb wrote:I found matte poly has no shadow at Kernel alpha shadow,this is why light fog no shadow effect ,so it is a bug ;)
Still not sure where I'm supposed to see this bug in your example scene.
Can you show the difference between the result you have with V2 and V3 ?
Because when I render your scene, the plane have a shadow and let the light only go trough the hole, as supposed:
Posted: Tue Jan 10, 2017 7:31 am
by renmaxhb
The attachment light_fog.jpg is no longer available
set poly with hole materier to matte
Posted: Tue Jan 10, 2017 9:29 pm
by calus
renmaxhb wrote: set poly with hole materier to matte
Ok I see the problem and the difference of behavior between V2 and V3, thanks Renmaxhb :)
If it's a bug it's not in the plugin, it's in octane core (same problem in standalone),
It might also be that the bug is the behavior of V2 and it was fixed or maybe this have been changed on purpose for another reason (but I don't think so) .
I have asked in standalone Section:
viewtopic.php?f=24&t=58323&p=301016#p301016
