octane parms ?
Posted: Fri Dec 30, 2016 5:14 pm
by pasto
Hello,
On a huge scene, Object level Octane parameters are just desapearing from time to time.
And I can't seem to be able to add them again, I must restart Houdini.
Any hint about this ? Is this a now bug ?
Thanx a lot
jérôme
Re: octane parms ?
Posted: Sat Dec 31, 2016 10:14 am
by juanjgon
If you can't add the OBJ parameters, I'm fairly sure that it is because they are already there, but perhaps they are not in the right place (I've seen the Octane tab embedded in other tabs or under the main tabs set sometimes, but I'm not sure why). Have you tried to use the tool to remove the OBJ spare parameters? The tool should remove them, even if they are not in the right place, so later you should be able to add them again.
Re: octane parms ?
Posted: Sun Jan 01, 2017 11:02 am
by pasto
Thanx for the answer,
Indeed the tabs get totally messed up sometimes (very erratic behaviour, I can't reproduce it at will), I don't know why.
Might be an Houdini specific problem though because I lost some camera options display too.
Happy new year anyway ! Best wishes for Octane.
Jérôme
