Windows 10 freezing frequently (off topic)
nuno1980
I've EVGA GTX 980 Ti SC+ ACX 2.0+ running Win 10 x64 1st anniversary but I don't get any freeze nor render failed yet :D when the render during several hours/days. Sorry... ;) But due to your abnormal videocard.
PT vs PHT kernels - spp nrs
Caustics at PT
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3 :mrgreen:
NEW ViewSonic XG2431 24" :D
Savi089
Hey guys,
I finally found a solution to this problem. Just turn off Intel VT (only needed for virtual machines...) in your bios settings and immediately the systems runs perfect with windows 10 again (not even a single crash in 2 month now / anniversary and creators updates).
Shoutout to a guy in the nvidia forums who found this fix! Sadly it took almost a year to find that setting, which is enabled by default in most bios´s.
Win10 | Ryzen 7 1700 | 1x 980ti + 1x GTX1060 + | 32gb | Cinema4D and Octane Plugin
protovu
Sorry for your hassles.
Just this December, following some Win7 alarming freezes, and years of not being able to boot with peripheral hard drives attached,
I was advised to switch my DualXeon, 4 Graphics card machine to Win10.
The tech guy that advised this ran into many headaches trying to upgrade the existing Win7. Ultimately, he did a clean install of Win 10.
More hassle for me, as I had to dial everything in for a week or two, but.....
Honestly, so far so good. I am told that Win10(pro) allows for more efficient use of the dual CPUs, and at some point Win7 support will fall off.
I disabled many of the unnecessary bells and whistles of Win10 to make it run a bit more quickly.
Hope this helps
smicha
protovu wrote:Sorry for your hassles.
Hope this helps
UEFI boot may be also helpful. Moreover if you are C4D user make sure to turn off internal renderer... And always set power plans to max performance.
Indeed a good clean windows install is a key for solving some issues and keeping a backup...
Return to “Off Topic Forum”
