animate rhino camera parameter DOF and FOV
Posted: Fri Dec 16, 2016 9:33 am
by v-cube
Hello Paul,
I am working on a large project which involves animation. I have successfully exported some bongo camera animation as ocs / abc files (I suppose the abc files are defining the animation settings?).
However, I have not been successful in transferring the animated FOV and DOF Parameters of the camera, although I enabled the options "sync octane focal depth to Rhino" and "sync octane FOV to Rhino". within Rhino, when moving the timeslider, the values are animated and octane renders them correctly in the octane frame buffer, but somehow the are not exported into octane standalone.
I do not know if this is a bug or simply not implemented yet. If the later is the cause, then please make it a wish, It would enable the rhino / Bongo combo to archive a basic level for animation control and would make my life so much easier...
please please!
Andreas
P.S. please excuse the stupid and OT question: Right now there is no way to animate value within octane standalone right? or am I missing something here...?
Re: animate rhino camera parameter DOF and FOV
Posted: Fri Dec 16, 2016 6:19 pm
by Marvez
Hello Andrea,
as a big rhino user and recently getting into animation- the .abc contains the animation and I have found using Blender.abc file to port the animation discreetly into Octane standalone and replacing the camera and geometry while keeping the animation content works .
I don't know if this helps your question , while I have this workflow very flexible and happy with the results
-Will
Posted: Sat Dec 17, 2016 2:26 am
by face_off
Hi Andreas.....to animate the FOV/DOF you need an ABC file containing the camera track to plugin into the Octane Rendertarget Camera pin. I will see if I can add these two parameters to the ABC file generated by the Rhino plugin in the next release.
Posted: Sat Dec 17, 2016 10:14 pm
by face_off
I have posted a pre-release of the plugin which will hopefully provide the DOF and FOV in the exported ORBX/OCS file. It is available from the Octane 3 TEST/STABLE release thread.
Posted: Mon Dec 19, 2016 12:36 pm
by v-cube
Thank you Paul !!!
I will test it ASAP
best
Andreas
Posted: Fri Jan 06, 2017 10:30 am
by v-cube
face_off wrote:I have posted a pre-release of the plugin which will hopefully provide the DOF and FOV in the exported ORBX/OCS file. It is available from the Octane 3 TEST/STABLE release thread.
Hi Paul,
I have installed the release (3.0.5.76) the animation of the DOF works now, but I seem to have lost my ability to network render, the interface does not show any clients (I have of course installed the latest 3.05.2 version of octane standalone and the daemon on the slaves...) the standalone version finds them!
can anyone confirm this?
best
Andreas
Posted: Fri Jan 06, 2017 10:59 am
by v-cube
Hi Paul,
best
Andreas
... never mind ... installed 3.05 and now it seems to work...
best
andreas
