Vertex Map inside of a Layer in Diffuse Channel
Posted: Tue Dec 13, 2016 4:18 pm
by DrJay
Hi everybody!
I have an unsolved situation concerning this:
If i'm using the Cinema 4D Vertex Effect inside of an octane material im getting my expected result.
When i now put the vertex effect into a layer - the material is getting just white. How that? The normal C4D renderer is doing fine with layers and vertex maps.
I'm using Cinema 4D R16 with Octane 3.04.5R2
thank you for any hints!
Re: Vertex Map inside of a Layer in Diffuse Channel
Posted: Tue Dec 13, 2016 4:38 pm
by aoktar
What's "layer" meaning here?
Posted: Tue Dec 13, 2016 4:59 pm
by DrJay
the layer "effect" from the menu where you will find all other effects.
It's that pice that allows you to combine different effects inside one channel
Posted: Tue Dec 13, 2016 5:01 pm
by aoktar
DrJay wrote:the layer "effect" from the menu where you will find all other effects.
Ok i know. Vertexmap implementation is not a type of textures which can be sampled by cpu. So it's not meanful with layer shader.
Posted: Tue Dec 13, 2016 7:46 pm
by DrJay
Allright, given that - which options do i have to maybe add some noise to a vertex map which is linked into a meterial channel instead of using layers?
Posted: Tue Dec 13, 2016 8:09 pm
by aoktar
DrJay wrote:Allright, given that - which options do i have to maybe add some noise to a vertex map which is linked into a meterial channel instead of using layers?
You can use anythings like octane shaders with multiply texture. Also you can use c4d noises. But remember that using c4d shaders will cause extra calculation times before rendering. They are rendered to images to be used.
Posted: Wed Dec 14, 2016 3:03 pm
by DrJay
Allright, using the multiply effect to use my vertex map as a layermask did the Job :-) thanks a lot.
Posted: Sun Jan 29, 2017 5:41 am
by djs01
VERTEX MAP ABLE TO BE USED:
Use the newest Octane Version which has the vertex map node available within the node editor
use a mix material and hedge between the two following videos;
(my c4d file is too big too share)
https://vimeo.com/155643512
https://www.youtube.com/watch?v=xXx_G6Kb36w
