OctaneRender™ for Blender 3.04.3 - 11.10 Linux [OBSOLETE]
Posted: Fri Nov 04, 2016 1:43 am
OctaneRender™ for Blender plugin. Linux x64 version.
1. OctaneRender™ Server
After the server is run - you can start rendering (or open a rendered view) from inside Blender. Before the very first rendering you should fill in the server address.
viewtopic.php?f=33&t=51679
Installation:
- Just run the installer to see its command line keys.
- If you need to run the OctaneServer - run it as daemon:
DOWNLOAD
Blender Octane Edition - v11.10 Linux
DEMO is available..
Blender Octane Edition DEMO - v11.10 Linux
viewtopic.php?f=24&t=57153
Please, if you decided to report a bug:
- Don't post in Blender section the reports about how Octane engine works - use the Octane Standalone forum sections for that.
- Give a meaningful description about what you think is wrong and how to reproduce it (in addition to screenshots if any). I can't solve the "one screenshot" rebuses without any meaningful description...
- If you use Google-translator to post here - check please what you got before posting it, and edit it before posting. Ask your friends to check it if you don't speak English.
- Implemented a full group nodes support. In previous versions Octane did not see groups if they were connected directly to shader output node (only to other nodes). Now this works.
Installation:
$ OctaneServer &DOWNLOAD
DEMO is available..
