Blocks with off layers showing up in octane render view
Posted: Wed Oct 26, 2016 8:00 pm
by polywog7
Hi Paul, Im up to date on the current stable build, so not sure if you may have already seen this in the test build.
I just noticed an old error seems to have come back. If I have a block instance with multiple objects on different layers, and I turn one layer off, when I render in octane, the off layer objects show up as if the layer is on.
Im not sure if there is anything new I need to do to get around this, but just wanted to point it out. Thanks!
Re: Blocks with off layers showing up in octane render view
Posted: Wed Oct 26, 2016 9:42 pm
by face_off
Do you have a sample scene you could send me demonstrating this issue pls? It's not something that has changed for a long time.
Posted: Wed Oct 26, 2016 10:54 pm
by polywog7
Hey Paul,
Here's a file for ya. I realized that the problem is only on blocks within blocks. You can see in the attached file and img.
-Nick
Posted: Thu Oct 27, 2016 11:30 am
by face_off
Thanks for providing the file. This issue will be fixed in the next release.
Posted: Thu Oct 27, 2016 1:43 pm
by polywog7
Awesome! Thanks.
Posted: Thu Oct 27, 2016 11:01 pm
by face_off
Below is a test release with the above fix. Can you pls let me know if it resolves your issue.
https://render.otoy.com/customerdownloa ... 4_1_74.rhi
