OctaneRender™ for Blender 3.04 - 11.4 OSX [OBSOLETE]
Posted: Thu Oct 20, 2016 10:10 pm
by JimStar
This is a TEST version. It may have some bugs, please don't use it for production. Please report the bugs in a Bug Reports section of Blender forum.
OctaneRender™ for Blender plugin. OSX version.
1. OctaneRender™ Server
To stop the server - just click its icon in the tray.
After the server is run - you can start rendering (or open a rendered view) from inside Blender. Before the very first rendering you should fill in the server address.
  • New Octane 3.04 core.
  • Fully reworked the export functionality. Implemented the asynchronous behaviour for Octane export, now it does not block the UI. Other export improvements...
  • Implemented new functionality for complex hair coloring. New Octane's settings in particle systems: "Min. W" and "Max. W". Now you can map different parts of color gradient (assigned to a mesh) to different hair particle systems, so different hair strands of same mesh could have different root-to-tip gradients. For automatic W interpolation use "Hair length" or "Segment count" options in the new "Hair W interpolation" setting of a mesh object. If you want to fine-tune this manually (using new "Min. W" and "Max. W" settings of a hair system) - set it to "Use hair Ws".
  • New "AO ambient texture" parameter in Octane direct lighting kernel. You can set it the same way as you do for texture/medium in Octane environment settings. Please read a standalone manual about this parameter.
  • Other new things brought together with 3.04 core (some new nodes, pins, etc...). You can read about them in Octane standalone 3.04 release notes.
  • Minor fixes and improvements...
You can read about new features of OctaneRender™ 3.0 here:
viewtopic.php?f=33&t=51679
Installation:
- Just run autoinstaller file.
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
Autoinstaller: Blender Octane Edition - v11.4 OSX Autoinstaller
ZIP archive: Blender Octane Edition - v11.4 OSX ZIP
DEMO is available..
Autoinstaller: Blender Octane Edition DEMO - v11.4 OSX Autoinstaller
ZIP archive: Blender Octane Edition DEMO - v11.4 OSX ZIP
viewtopic.php?f=24&t=56856
Please, if you decided to report a bug:
- Don't post in Blender section the reports about how Octane engine works - use the Octane Standalone forum sections for that.
- Give a meaningful description about what you think is wrong and how to reproduce it (in addition to screenshots if any). I can't solve the "one screenshot" rebuses without any meaningful description...
- If you use Google-translator to post here - check please what you got before posting it, and edit it before posting. Ask your friends to check it if you don't speak English.
