Page 1 of 19
Version 3.04.5-R2 (05.12.2016)-Previous stable
Posted: Tue Oct 18, 2016 11:32 pm
by aoktar
Here is a new version which is based latest SDK 3.04.5.
Enjoy it!
Standalone V3.04.5: viewtopic.php?f=24&t=57660
Changes of V3.04.5-R2
- Fix: VertexColor(R18) issue
- Fix: Memory leak for ImageTexture in Picture Viewer rendering.
Changes of V3.04.5
- Vertex weights and Vertex Color support. Note that: Octane render has not real support for this. And plugin simulates vertex weights by generating images. So this is a bit limited for some cases.
Changes of V3.04.3-R1
- Fix the crash on livedb with deleted localdb dir
- Fix wrong scaling of TFD. Just works with uniform scaling.
Changes of V3.04.3
- Mograph support for Voronoi object
- SDK 3.04.3 fixes(see standalone link)
Changes since 3.03.3-R1
- fix on instance engine. Fixed some update problems with visibility changes, etc...
- Added W gradient node for hair gradients.
- Animated ORBX improvements
- fix: TurbulenceFD container rot/scaling
- Added more object masks
- reversed z-axis orientation for VDB volumes
- fix: Node editor(OSX) RMB-context menu problem
- Alpha/opacity support for materials in viewport with octane shading.
- Volume objects will support objecttag parameters as opacity/layerID/etc... anymore.
- GI_AMBIENT/GI_SAMPLE_AMBIENT removed from GI mode of Direct Lighting Kernel. Check your settings of your old scenes.
-AO ambient texture has been added to environment tag. It will work on DL kernel with AO mode.
MATERIAL STACKING LIMITATIONS
- Only works with c4d materials and octane materials and will not work with mix materials in any combination
- Works on movable meshes. So it requires to be in auto mode for LV or auto detect for PV or object tag in manual mode. Doesn't work on "Send all data" method.
- Works with flat/cube/cylindrical/spherical projection types. Tiling support. Doesn't account the current tag's UVW mapping coordinates. It takes it from previous material which has not alpha/opacity.
- Can work with selection assignments. But it's still limited on complex selection sets
- Go with mix material setups for advanced usages
Requirements:
-You'll need to update your Cinema 4D to latest versions(16.050, 17.053 or 18.028). Otherwise the plugin will not work and not appear in menus.
-Internet connection for activation, be sure that C4D and Octane will not be blocked by firewall and any antivirus software.
-Updated Nvidia drivers(at least 344.x(Cuda 6.5 or later) for V2.x, Cuda 7.5 for V3.x.
OctaneRender for Cinema 4D Commercial version
WINDOWS 3.04.5-R2: https://render.otoy.com/customerdownloa ... win-R2.zip
OSX 3.04.5-R2: https://render.otoy.com/customerdownloa ... Macosx.zip
OctaneRender for Cinema 4D Subscription version
WINDOWS 3.04.5-R2: https://render.otoy.com/customerdownloa ... R2-win.zip
vm.zip
Vertex map scene
(308.77 KiB) Downloaded 972 times
MANUALS: (extract to c4doctane dir.)
Offline HTML: https://render.otoy.com/plugindownloads ... ual-V3.zip
Online manual: https://docs.otoy.com/#60Octane%20Rende ... r%20Manual
V3 SAMPLE SCENES SET(make a request if you need any spesific sample)
https://render.otoy.com/plugindownloads ... scenes.rar
See this topic for some partial samples: viewtopic.php?f=85&t=53989
CINEMA 4D TUTORIALS SECTION: viewforum.php?f=87
CHANGE LOG: https://docs.otoy.com/#60Change%20log
Installation
First remove all octane related stuff from plugins and main folder of Cinema4D.
Also download manual.zip and extract to c4dOctane directory if it's not available in place.
Ex. if you have Cinema4D R16.0, keep only "c4dOctane-r16.cdl64" and delete c4dOctane-r15.cdl64, c4dOctane-r14.cdl64, etc..
Cinema 4D Release 13: c4dOctane-r13.cdl64
Cinema 4D Release 14: c4dOctane-r14.cdl64
Cinema 4D Release 15: c4dOctane-r15.cdl64 or c4doctane_R15_demo.dylib
Cinema 4D Release 16: c4dOctane-r16.cdl64 or c4doctane_R16_demo.dylib
Cinema 4D Release 17: c4dOctane-r17.cdl64 or c4doctane_R17_demo.dylib
PLEASE IMPORTANT NOTICE
New License system:
We'll run it over the new license system and login window anymore. So you'll need to enter OTOY userid and password to able run the plugin and standalone. This is same combination to entering for Account page of Otoy.
This mean that you shouldn't try to use plugin id/pass pairs since this time. Also this system choose one of your licenses if you have many.
On any login issues see this post and topic:
viewtopic.php?f=30&t=54208&start=50#p276063
If you have C4D startup hangups try to delete these files.
Windows: %APPDATA%/OctaneRender/otoy_credentials
OSX: ~/Library/OctaneRender/otoy_credentials (you may have to use Finder's Go->Go To Folder... and type "~/Library/OctaneRender" - without the quotes - to get to that folder)
CUDA requirements
Due to a CUDA compiler bug we had switch to CUDA 7.5, which means on Windows and Linux you may need to update your NVIDIA graphics driver to a current version which supports at least CUDA 7.5. On Mac OSX you may have to update the CUDA driver for Mac to a current version supporting at least CUDA 7.5.
BUG REPORTS
I'll be happy, if anyone can be specific on their bug reports.
I need to know that your plugin version/Os/HW and last operations before crashes to reproduce and investigate the same problem.
And please attach a SCENE and BUGREPORT.ZIP.
Please post your reports in topic of version which is related or use bugreports section of this forum
Thanks for contributions
Re: Version 3.04-R1 (19.10.2016) - TEST
Posted: Wed Oct 19, 2016 6:46 am
by TBA3D_70
The OS X version has a empty "res" folder after downloading :(
I copied the missing files from the 3_03_4_R3 version into the "res" folder.
--> This works! ...but (?)
Best regards,
Thomas
Posted: Wed Oct 19, 2016 9:46 am
by KonstantinosD
Can someone please show an example of this new W gradient node for hair and is it possible now to map a texture (grass) along the height of the hair Like in C4D materials?
Also awesome release, super fast , Ahmet rules!
Posted: Wed Oct 19, 2016 10:21 am
by aoktar
TBA3D_70 wrote:The OS X version has a empty "res" folder after downloading :(
Best regards,
Thomas
Not a good idea. Somethings can be different. I have fixed the downloads.
Posted: Wed Oct 19, 2016 10:27 am
by aoktar
KonstantinosD wrote:Can someone please show an example of this new W gradient node for hair and is it possible now to map a texture (grass) along the height of the hair Like in C4D materials?
see image. You need to add octane material to hair geometry.
Posted: Wed Oct 19, 2016 11:41 am
by martincarlson
Sweet Ahmet!
I notice the DirtFallof-function is not in your list of updates. Just saw this in the Standalone-update.
See here: viewtopic.php?f=24&t=56856
Is this in a later update?
Posted: Wed Oct 19, 2016 11:45 am
by aoktar
martincarlson wrote:Sweet Ahmet!
It's in plugin. I miss to update the notes sometimes. Thanks for noting that!
Posted: Wed Oct 19, 2016 11:46 am
by martincarlson
COOL! Thanks
Posted: Wed Oct 19, 2016 2:35 pm
by RahiSan
Great, thank you!
Posted: Wed Oct 19, 2016 5:14 pm
by atome451
Thanks a lot Aoktar! :)
For your information, there is no node anywhere for the "W Coor" in the Node Editor interface.
By the way, it works fine if you add the "W Coor" node from the standard C4D material editor. Not a big problem then... :roll:
