Page 1 of 2
octane render to dependencies parameter in poser
Posted: Mon Oct 17, 2016 8:00 am
by Andygraph3D
Is now possible use the dependencies to materials poser and render it in animation ?
Re: octane render to dependencies parameter in poser
Posted: Mon Oct 17, 2016 11:47 am
by face_off
I'm sorry - I don't understand the question that you are asking.
Posted: Mon Oct 17, 2016 4:35 pm
by wimvdb
In the setup of the plugin you turn on dial linking.
What it does is the following:
If you have an animated texture in Poser (animated option, so it appears as dial), it will be available as variable in floating point values and in greyscale color (0-1 inputs). In the properties of that node you can find the option "control from dial". Select the dial there
Be aware though that turning on can make the plugin UI quite slow.
Posted: Mon Oct 17, 2016 4:54 pm
by Andygraph3D
wimvdb, so i can render the animated opacity or others material effects linked to poser dial ?
I can make it from what plugin version ? v3.0 to above ?
Posted: Mon Oct 17, 2016 8:34 pm
by wimvdb
Andygraph3D wrote:wimvdb, so i can render the animated opacity or others material effects linked to poser dial ?
Yes, you make that opacity dial animated (press key icon left of the value in poser mat room.
That material will now a appear in the prop or figure. This dial can be used in the plugin if the dial option has been set.
In the material itself in the plugin, look at the properties of the opacity, it can now be set to be driven by dial.
Plugin reads the value again each frame, so if the value changes, it will change the value for that in octane (in your case opacity).
Paul has implented that some time ago and I have used to render particles 3+ materials in octane. Those particles change their opacity depending on their age.
No idea when it was introduced. I was in v2 of the plugin
Posted: Tue Oct 18, 2016 8:03 am
by Andygraph3D
Many thx!!!
Where i can find the all infos plugin release and features ?
Posted: Tue Oct 18, 2016 11:12 am
by face_off
Posted: Thu Oct 20, 2016 8:34 am
by Andygraph3D
Hi Paul !
I have the 2.24.1.61 32bit, but i dont see the dial option on material ..
i have poser 10 32bit
Posted: Thu Oct 20, 2016 9:14 am
by face_off
Tick the Dial Linking option in the plugin settings.
Posted: Wed Nov 23, 2016 8:58 am
by Andygraph3D
Paul, where is Dial Linking option in plugin setting ?
