Material database and node editor.
Posted: Sat Oct 08, 2016 2:54 pm
So since it's release I've always use the node editor and I also have been using the material database more a more (the local database) and well I thing I've a few suggestions for improved funtionality as well as a couple of bug reports:
Material database:
- Database search function it's broken.
- When you rename the material in the DB the name doesn't change even if you reload the windows or restart Cinema 4D, actually the file name itself does change and when you download the material the new name shows up but still the new name needs to be displayed in the DB aswell.
- Option to override or update the material (like for example drag the material on top and get a pop menu asking to update).
- Being able to drag and drop materials from the DB to the material manager (for downloading).
- View materials as list. (I really really want this.)
Node editor improvements:
- When creating a transform or projection right in the texture option the node doesn't show up right away, same thing happens when you create a sinewave from the gradient node.
- Keep connections and references when you save materials into the DB, for example when you load a material what was originally only one transform node connected to several image textures is now X number of transform nodes one per each image texture node (this happens when you have references to several materials).
- Fix bug "error loading texture", when you load a material from the data base you get an error in the image texture nodes when you render the scene the textures does load but having that error there besides being annoying also means that you can't click the Edit button to check the texture.
Lastly I just want to clarify that I'm not mad for the lack of these features or something, the plugin is great as it is right now but things like "View materials as list in the BD" would make me incredible happy.
Material database:
