AO pass MultiLayer EXR
Posted: Thu Sep 29, 2016 4:41 pm
by LFedit
When I save a multilayer EXR, my AO pass looks as followed. Every time. Anyone get this?
Re: AO pass MultiLayer EXR
Posted: Thu Sep 29, 2016 10:04 pm
by face_off
Which version of the plugin pls? Can you try with the latest TEST release pls?
Posted: Fri Sep 30, 2016 3:09 pm
by LFedit
I just upgraded to the latest version of the plugin and Octane and still doing the same thing. It weird, if you open the exr in photoshop the AO pass will be messed up like that, then you can toggle the visibility and it changes every time to different messed up colors.
Posted: Fri Sep 30, 2016 10:13 pm
by abstrax
LFedit wrote:I just upgraded to the latest version of the plugin and Octane and still doing the same thing. It weird, if you open the exr in photoshop the AO pass will be messed up like that, then you can toggle the visibility and it changes every time to different messed up colors.
The AO pass and several other info passes are stored as greyscale layers, i.e. have only one channel. Loading them as RGBA doesn't work. How do you open them in Photoshop using the workflow plugin or something else?
Posted: Mon Oct 03, 2016 3:44 pm
by LFedit
I just open them as an exr in photoshop. Should I try the plugin to open it?
EDIT: Just tried to open the octane compositing project. How do I save a .ocprj file form Octane?
Posted: Mon Oct 03, 2016 10:22 pm
by face_off
Last time I tried - when I loaded an EXR in Photoshop, the Octane plugin automatically loaded it - /however/ there was a bug in the plugin where Photoshop was placing the "EXR Import" options dialog (to set the gamma) behind the main Photoshop window. You need to click OK on that dialog first. Then selecting the Ambient Occlusion layer worked fine.
