OctaneRender™ 3.0 for LightWave™ - Production build 3.03.4.1
Posted: Tue Sep 20, 2016 8:52 am
Hi! This is the latest production build of the OctaneRender™ 3.0 for LightWave™ plugin, available for Lightwave 10.1, 11.6 and 2015.3 Windows x64 and OSX.
Release 3.03.4.1
https://render.otoy.com/customerdownloa ... indows.zip
https://render.otoy.com/customerdownloa ... .1_OSX.zip
Release 3.03.4.1 DEMO VERSION
https://render.otoy.com/plugindownloads ... s_DEMO.zip
https://render.otoy.com/plugindownloads ... X_DEMO.zip
Standalone version for the network rendering nodes
https://render.otoy.com/customerdownloa ... _4_win.exe
How to install the plugin
- (Only for Windows) Remove all the old Octane plugin files (octane.dll, octane.dat and the .p plugin file)
- (Only for Windows) Copy the octane.dll, tbb.dll and octane.dat files into you install Lightwave/bin directory. You must overwrite the LightWave tbb.dll file.
- Add the plugin to the Lightwave Layout.
- Install the custom menu bar to get access to the Octane features.
New features
A list of all the new features is provided here: viewtopic.php?f=33&t=51679
The plugin manual is going to be updated in the next weeks to cover most of the changes. https://docs.otoy.com/manuals/products/lightwave-3d/v3/
RELEASE 3.03.4.1
* PLUGIN BUGS FIXED:
- The Octane_lights are included in the baked textures while working with the baking camera. Fixed.
- Fixed some IPR navigation problems in the perspective mode.
- IPR zoom sensitivy adjusted for the orthographic camera.
- The beauty pass in the multi-layered EXR files now has the standard RGBA channel names.
* OCTANE BUGS FIXED:
- Fixed incorrect fallback to the primary environment when the visible environment is black.
- Fixed volume bounding box sometimes casting a shadow when using environment medium.
- Fixed occasional kernel hang during the displacement intersection test, usually resulting in the that the OS kills the graphics driver and lots of CUDA error messages are dumped to the log.
- Fixed infinite loop that sometimes occurs in scenes with lots of transparent surfaces.
- Fixed ray-sphere intersection for rays starting inside the sphere.
- Fixed occasional issue with PMC seeding resulting in inconsistent brightness in animations.
- Fixed incorrect weighting of render layer passes in areas where blurry/transparent objects of the active layer lie in front of the inactive layer (see viewtopic.php?f=30&t=55903 ).
- Fixed some baking artifacts caused by disagreement between geometric normals and smooth normals (see viewtopic.php?p=284803#p284803 ).
- Fixed the tangent normal pass, which was only displaying perturbations along the U axis.
- Fixed crash in deep pixel rendering when the film size is smaller than the maximum tile size (which is rounded up to a multiple of 4 in each dimension).
- Fixed incorrect size of temporary tone map result buffers. This should help with tone mapping renderings with huge resolution.
- Fixed swapped tone mapping behaviour when HDR image are saved via the viewport save drop-down.
Release 3.03.4.1
New features
RELEASE 3.03.4.1
