Page 1 of 2
Unwanted motion blur with the Stage object
Posted: Thu Sep 08, 2016 12:39 pm
by Yambo
I'm working a lot with the Stage object to switch between cameras and direct my shots inside c4d.
There is an annoying issue with the motion blur while keyframing between cameras - Octane "thinks" the camera is moving very fast from the first camera position to the second camera position and there is this unwanted motion blur for 2-3 frames.
Ahmet, is there any way to fix it easily?
Video attached for a better explanation.
Y
Re: Unwanted motion blur with the Stage object
Posted: Thu Sep 08, 2016 1:03 pm
by aoktar
reported on another post. Yes plugin get actual camera without knowing it's changed. I'm looking to solve the issue. May not be much easy to fix. Cut or rerender frames if you can.
Posted: Thu Sep 08, 2016 1:12 pm
by Yambo
Didn't notice the other post, sorry.
Yap, I'm cutting those frames usually, but since I'm working on a piece with a lot if intercuts it's eating too many frames.
Anyway I'm happy you aware of it. hopefully, it will be solved somewhere in the future
BTW - the AB compare feature is just great! love it.
Keep your great work sir.
Cheers
Y
Posted: Thu Sep 08, 2016 2:13 pm
by aoktar
Thanks! Btw are you happy with results on LV with stage object usage? I'm trying to use same method as in LV.
EDIT: i'm fixing issue. Any test to help fixing?
Posted: Thu Sep 08, 2016 11:57 pm
by DisplaceArts
I'm having this same issue with the stage object, and I can't really cut these frames out since I need the exact amount of frames when I export everything to AE.
But it's great knowing that others are aware of this issue and hope it can be resolved soon =)
Posted: Fri Sep 09, 2016 12:14 am
by aoktar
DisplaceArts wrote:I'm having this same issue with the stage object, and I can't really cut these frames out since I need the exact amount of frames when I export everything to AE.
Here is a test build for fixing the issue:
It's for windows.
https://render.otoy.com/customerdownloa ... -test1.rar
Posted: Fri Sep 09, 2016 10:45 am
by Yambo
Really?! wow, this is so great.
Seems like it works great, thanks so much, i will report if there is any issues
Posted: Tue Sep 13, 2016 8:07 am
by Yambo
OK
There is some weird bug with the motion blur now with some of my scenes.
Motion blur just killing the view, video attached.
Any idea?
Posted: Tue Sep 13, 2016 10:49 am
by aoktar
Yambo wrote:OK
Any idea?
What happen if you resend scene after switched the moblur?
Posted: Tue Sep 13, 2016 11:33 am
by Yambo
Same, nothing works.
Another annoying issue is that my c4d standard viewer got some very weird behavior sometimes for objects with Octane materials.
The materials making the geometry totally transparent, even there is a geometry behind it. it makes it behave like an object with render layer enabled, This is never happened to me before, I'll try to catch here and post here.
