Page 1 of 2
R18 Released! Octane Still Works!
Posted: Fri Sep 02, 2016 5:30 pm
by natemac00
Just got the email last night to download R18.
Download the software but have yet to install it. Has anyone tried Octane with it yet?
Once I get a break in the day, I'll give it a try but thought I'd see if anyone else has yet to brave into the upgrade.
UPDATE: It Works!
So I installed R18 and dropped the Octane plug-in in the the R18 plug-in folder. Loaded a scene and everything seem to render just fine....
There might be some other bugs hanging around since this was a very small test. But I was able to load a scene that I created in R17 and it seems quite identical in R18.
Have to stress test some of the other features, but at least I know I can render output just fine... But not deleting R17 anytime soon just to be safe.
Re: R18 Released! Octane Still Works!
Posted: Fri Sep 02, 2016 9:00 pm
by aoktar
Yes works since alpha. Please warn us if you catch any issues.
Posted: Tue Sep 13, 2016 8:26 pm
by hsmann
Can't delete Phong Tags when Live Viewer is on in R18, they resurrect whenever I click somewhere. No problem with C4D R17.
Posted: Tue Sep 13, 2016 8:57 pm
by aoktar
hsmann wrote:Can't delete Phong Tags when Live Viewer is on in R18, they resurrect whenever I click somewhere. No problem with C4D R17.
Make a new scene. Add a cube and assign a octane material. Try to delete phong. What's happening?
Posted: Thu Oct 27, 2016 9:24 pm
by ScottGelber
I'm not seeing octane when i install it in R18 is there a special installation method?
Posted: Thu Oct 27, 2016 9:26 pm
by natemac00
ScottGelber wrote:I'm not seeing octane when i install it in R18 is there a special installation method?
Nope, just put it in the plugin folder in your preferences and be sure you're using the R18 version of the plugin.
Posted: Thu Oct 27, 2016 9:34 pm
by ScottGelber
natemac00 wrote:ScottGelber wrote:I'm not seeing octane when i install it in R18 is there a special installation method?
where do i find the R18 version? I just downloaded the latest version listed
Posted: Thu Oct 27, 2016 9:35 pm
by natemac00
ScottGelber wrote:natemac00 wrote:ScottGelber wrote:I'm not seeing octane when i install it in R18 is there a special installation method?
open the plugin folder and delete all but the R18 inside it just as you've done with every previous release.
Posted: Thu Oct 27, 2016 9:45 pm
by ScottGelber
Nope, just put it in the plugin folder in your preferences and be sure you're using the R18 version of the plugin.[/quote]
where do i find the R18 version? I just downloaded the latest version listed[/quote]
open the plugin folder and delete all but the R18 inside it just as you've done with every previous release.[/quote]
there is no R18 in the folder, please be more specific, provide a link?, i don't see an R18 version in the downloads list
I appreciate your patience and help, i'm having a hard time
Posted: Thu Oct 27, 2016 9:46 pm
by natemac00
unzip the file you downloaded, open the folder and take a look inside. delete all but R18. then put it in the plugin folder.
