Object won't render in assigned layer
Posted: Sat Aug 13, 2016 5:53 pm
by NeutronTon
I am using Octane 3.03.2.0 on MAC an have specified layer 2 for an object while other objects are on layer 1. I have Enabled Layer Rendering (1-2), but still the object is rendered in Layer 1, not Layer 2. Am I missing something?
Re: Object won't render in assigned layer
Posted: Sun Aug 14, 2016 8:39 am
by juanjgon
I am testing the layers feature and it seems to work fine. Are you sure that you are not rendering two or more cloned objects loaded as instances in Octane? Try your scene disabling the "Instance LW clones" option in the render target root node options panel. The instances in Octane are going to share all the same layer.
Posted: Sun Aug 14, 2016 6:29 pm
by NeutronTon
Thanks for reply. Disabling "Instance LW Clones" worked! Thanks!
