Authentication failed: Could not connect to SSO server
Posted: Sun Jul 24, 2016 5:08 pm
by sdanaher
Installed 3.03 2b demon on Slave machine, now it won't retrieve its license. Like me this licensing debacle is getting old...
Re: Authentication failed: Could not connect to SSO server
Posted: Sun Jul 24, 2016 8:47 pm
by mojave
It's likely that you are using this machine with offline licensing mode. If that is the case and the machine has been offline for some time you'll need to bring the Internet connection up temporary as the licensing information needs to be updated when you update to a newer version, similar to how it used to be before the licensing system change. In order to do so, the server needs to be contacted, so that's likely why you see this message.
If you are still unable to activate your slave please reply providing a screenshot and all information that might be relevant.
Posted: Mon Jul 25, 2016 8:28 am
by sdanaher
mojave wrote:It's likely that you are using this machine with offline licensing mode. If that is the case and the machine has been offline for some time you'll need to bring the Internet connection up temporary as the licensing information needs to be updated when you update to a newer version, similar to how it used to be before the licensing system change. In order to do so, the server needs to be contacted, so that's likely why you see this message.
Not to my knowledge. Its been running the previous slave for weeks and is always online. Main Octane 3.03 2b app gives the same error when I launch it. How is off-line licensing enabled?
Posted: Mon Jul 25, 2016 8:29 am
by sdanaher
This is the info I get:
Do you want use offline licensing on this computer? (y/N)n
Authenticating ...
Unexpected response format:
Press any key to continue...
Posted: Mon Jul 25, 2016 1:13 pm
by bepeg4d
Hi sdanaher,
could you try to go in HD/Users/YourUser/Library/OctaneRender/ and delete the otoy_credentials file?
ciao beppe
Posted: Mon Jul 25, 2016 1:56 pm
by sdanaher
I seem to have got it working now... not sure why. I have a network protection app running (little snitch) to keep an eye on what comes in and goes out. It was reporting no connection to the server, even if I disabled the filter which was set to ALLOW the connection. I created a rule to allow all connections from octane and deleted references to specific servers. After that it worked, but its not clear why or if Little Snitch was the culprit, I have it running on my other machine too and there is no problem.
Posted: Mon Jul 25, 2016 7:28 pm
by Studiolocal
I have experienced this prompt also. I am on a PC and find it happens if I start the c4d app too quickly directly after a restart. Not sure if that's what causes it but that's when it's happened.
Posted: Mon Jul 25, 2016 8:07 pm
by mojave
Good to see you got it working, if you happen to find out more about why this please let us know.
Thank you.
Posted: Mon Aug 01, 2016 9:08 am
by nehale
I still have this issue and its not going away!
Posted: Mon Aug 01, 2016 9:18 am
by bepeg4d
Hi nehale,
what do you see if you go to your OctaneLive licenses page?
Have you activated the off-line option previously?
Have you tried to sign-out from the latest Standalone
v3.03.2?
Which version of c4dOctane are you currently using?
The latest version is here:
viewtopic.php?f=85&t=54672
ciao beppe
