Hi Paul, amazing work wih this new AI tools.
Can I ask you if you can make by default a button near the select viewport dropdown menu to toggle ai beauty/beauty render passes ?
Regards,
Vlad
OctaneRender 3 for Modo [OBSOLETE]
- marcus1070
- Contact:
I think it's a free memory amount issue.. on standalone, denoising runs ok, but with a long calculation time, the plugin takes more time or even longer...face_off wrote:This sounds like a non-plugin issue, so suggest you test in Octane Standalone and report to OTOY in the Octane 4.00 Standalone release thread if needed.I'm doing my first tests, and I have a question: is it normal that AI Light and Denoiser slow down renders instead of speed them up?
If you can provide an exact set of steps for me to follows to reproduce this issue, I will investigate further.Hi Paul!.. i got an issue with this test octane 4 build.. denoiser dont work with hd renders.. just on preview... but in standalone goes ok...
in modo plugin, when denoise pass runs, goes infinite and slow down everything..
"PS: i'm using hdmi audio, and some noises go on when i run anything that uses gpus, and there a diference between noises in modo plugin and octane"
- Win 10 Pro 64bit
- 64gb Ram
- RTX 3090
- RTX 2080
- Nvidia driver version: 516.94
- Cinema 4d r25
- Plugin version Studio+ 2022.1(r7)
http://www.marcusrizzo.com
- 64gb Ram
- RTX 3090
- RTX 2080
- Cinema 4d r25
Vlad not sure if this is what you are referring to but it's possible do this in the form editor. I added beauty / denoised beauty toggle buttons in the octane toolbar.v1adut wrote:Can I ask you if you can make by default a button near the select viewport dropdown menu to toggle ai beauty/beauty render passes ?
Regards,
Vlad
Dino Inglese
CG Artist
Melbourne Australia
Octane build 4.04.0.145
CG Artist
Melbourne Australia
I have updated the Octane 4.00 OSX build, and add a Linux build at the top of this thread.
I have updated the STABLE installers at the top of this thread with an Octane 3.08.3 build, which includes the relevant changes from 4.00.0.134.
Thank you very much , this is exactly what I was asking for.MrFurious wrote:Vlad not sure if this is what you are referring to but it's possible do this in the form editor. I added beauty / denoised beauty toggle buttons in the octane toolbar.v1adut wrote:Can I ask you if you can make by default a button near the select viewport dropdown menu to toggle ai beauty/beauty render passes ?
Regards,
Vlad
@face_off
Paul can you insert this in the octane next build ?
Regards,
Vlad
I have updated the Octane 4 TEST builds at the top of this thread with:
4.00.0.135
- Compiled with Octane 4.00 RC6
- Added the option to save an animation to OCS/ORBX from the Export button on the toolbar (this was previously done via the octane.saveAnimation command)
- Added support for the OSL Projection
- EXPERIMENTAL: Added code to speed up transform changes on large meshes. This only applies to Mesh items with Live Geometry Update ON, and when the Render Cache if OFF.
- EXPERIMENTAL: Added support for OSL cameras
- Added support for the OSL UV Projection node
- Updated the Modo SDK from Modo901 to Modo10
4.00.0.135
Have you tried deleting your modo .CFG file?I'm getting a crash on launch with the latest test build.
