TubulenceFD Volumes and transforms don't work
Posted: Thu Jun 30, 2016 8:14 pm
by shoqman
Hi there,
So I have a project where my TurbulenceFD container follows the emitter particles as they fly through the scene, which works great because then I can have much higher resolution than if I just made a huge volume to accomodate the whole animation.
The problem is, Octane apparently does not get the translate and rotation info from my Turbulence container, so it only renders a portion of the volume. In the viewport, it is all correct, but Octane sees it as if the rotation had not occurred, and only renders a piece.
Apparently this came up in the lightwave build and was supposedly given SDK access to it and it got fixed. Any way we can do the same for C4D?
Re: TubulenceFD Volumes and transforms don't work
Posted: Thu Jun 30, 2016 8:18 pm
by aoktar
It's supporting translate but not rotation.
Posted: Thu Jun 30, 2016 8:22 pm
by shoqman
Yes, you are right. My bad, it's just the rotation that we need now.
Posted: Thu Jun 30, 2016 8:30 pm
by aoktar
shoqman wrote:Yes, you are right. My bad, it's just the rotation that we need now.
I'm not this atm. Please use a workaround for that now.
Posted: Fri Jul 01, 2016 8:26 pm
by shoqman
Ok, no worries. Just wanted to make sure it was a known thing. Thanks.
