Render Contrast and Color Accuracy
Posted: Fri Jun 17, 2016 7:45 pm
by reality-1
Howdy!
I've been racking my brain trying to figure out how to get the file saved by (Octane-plugin) to look like the preview window. So far everything I've tried gives me a washed out lower contrast product in the output file.
Is there a proper way to approach this?
Still loving Carrara with the Octane plugin!
-John
Re: Render Contrast and Color Accuracy
Posted: Thu Jun 23, 2016 10:50 am
by PhilW
There shouldn't be a difference - what format are you using to save the file? It sounds like it could be a gamma issue, but this shouldn't really be an issue with saved files.
Posted: Thu Jun 23, 2016 12:14 pm
by RobSteady
Having the same problem with 3ds Max - its not a gamma issue, the difference is too subtle but still noticable; the saved frame is missing a bit of contrast and color dynamic.
Posted: Thu Jul 28, 2016 10:07 pm
by reality-1
PhilW wrote:There shouldn't be a difference - what format are you using to save the file? It sounds like it could be a gamma issue, but this shouldn't really be an issue with saved files.
This issue may have had something to do with a display upgrade.
When I reconnected a display that was previously connected when I installed Octane, the problem went away and I haven't been able to reproduce it.
I suspect the OctaneRender view port and the file saving API's may have been using different color profiles.
-John
Posted: Thu Jul 28, 2016 10:13 pm
by reality-1
RobSteady wrote:Having the same problem with 3ds Max - its not a gamma issue, the difference is too subtle but still noticable; the saved frame is missing a bit of contrast and color dynamic.
This issue might be a color profile hanging around after the display device is changed.
Have you changed your display hardware?
I reconnected my original display device and the problem went away.
-John
