Dof problem with Octane 3
Posted: Thu Jun 02, 2016 11:32 pm
by marchermitte
Hello!
I'm playing with a scene and I can't get the dof to work ... I do what I always do , use a distance from / to, item info on the caméra and a focus null object but now nothing seem to work. I pushed the aperture far (50 , 100), nothing.
I also tried without the distance to nodes setup, plain octane aperture, nothing. It seemed to work in the beginning and then, no more.
Anybody else?
thank you
Re: Dof problem with Octane 3
Posted: Fri Jun 03, 2016 7:54 am
by juanjgon
I suppose that you don't have the autofocus option enabled, right? Can you send to me the .lws scene file?
Posted: Fri Jun 03, 2016 8:55 am
by marchermitte
No Autofocus... I did try (because It wasn't working with my rig, the exact same that worked with Octane2.x ) to enable It , pick the focus in the IPR but still nothing.
https://drive.google.com/file/d/0Bz71I8 ... sp=sharing
Thank you!
Posted: Fri Jun 03, 2016 9:07 am
by juanjgon
The problem is that you have the "Aperture edge" parameter set to 0.0. If you set it to 1.0 all should work fine ;)
Posted: Fri Jun 03, 2016 10:10 am
by marchermitte
Ok, I had changed It before without noticeable changes BUT to see the result I have now to crank up the aperture to 50 or a 100! Not sure if It's due to my scene scale or to the changes since Octane 2.
It works now, thank you!
Posted: Sat Jun 04, 2016 5:03 pm
by LightwaveGuru
marchermitte wrote:Ok, I had changed It before without noticeable changes BUT to see the result I have now to crank up the aperture to 50 or a 100! Not sure if It's due to my scene scale or to the changes since Octane 2.
its your scene size...
snip lwguru
