Page 1 of 4
TurbulenceFD & Octane tutorial
Posted: Sat May 28, 2016 1:50 pm
by wireframex
Hi there,
I'm looking for a tutorial to use TFD with Octane.
Anyone can help me ?
Phil
Re: TurbulenceFD & Octane tutorial
Posted: Sun May 29, 2016 10:44 am
by juanjgon
In the next weeks I'll work in the updated Octane 3 plugin docs, with a section related to the volumetric rendering.
Anyway working with TFD and the LW plugin is fairly easy. The plugin works with the TFD cache files. You only need to add the Octane_volumetrics custom object plugin to the TFD container object, set the volumetric mode to TFD, select the path of the TFD cache files and select the grids used by Octane to render the volume.
Finally you need to configure be the medium shader node to be used with this volume. You need to use the Octane_volumetrics custom object node editor and link inside the volume medium material.
Posted: Sun May 29, 2016 7:33 pm
by wireframex
Posted: Sun May 29, 2016 7:53 pm
by wireframex
There is somtething strange ... I didn't found the Octane Volume Medium ?
[img]http://pll_3d.perso.sfr.fr/Octane/Octane_Volumn.jpg[/img]
Phil
Posted: Mon May 30, 2016 9:30 am
by juanjgon
You need to remove the old Octane 2.2 plugin and add the Octane 3 plugin again in the Layout to see the new nodes.
Posted: Mon May 30, 2016 5:00 pm
by wireframex
I removed 3 times the plugin and install the new one and after the third try finally its Ok
Very odd.
Phil
Posted: Fri Jun 17, 2016 10:55 pm
by marchermitte
Hello!
Trying for the first time to render a turbulence scene, I get this message: "TDF library not found in """. Any idea what I did wrong?
Posted: Sat Jun 18, 2016 8:22 am
by juanjgon
marchermitte wrote:Hello!
You need to set the path to the TFD plugin in the options panel.
Posted: Sat Jun 18, 2016 8:25 am
by marchermitte
That was It! Thank you!
Posted: Sat Jun 18, 2016 10:48 pm
by marchermitte
The problem (TFD library) is now solved now but nevertheless I can't see anything in the IPR. I set the cache folder properly, added to the container the volumetrics custom object, connected the volume medium to the volumetrics node... still nothing. Tried the path tracing kernel and direct lighting (which I guess might not work)
