OpenVDB --> instant crash
Posted: Thu May 26, 2016 10:59 am
by Hesekiel2517
Hallo,
if i load a openvdb file via the openvdbvoxelitem and hit render Modo crashes instantly. The vdb File is generated from Blender and loads both in the Standalone and the Modorenderer just fine. Is there a solution to this?
Great work on the Plugin by the way!
PS: I use the latest Versions of Modo, Blender, Octane and Octane Plugin
Re: OpenVDB --> instant crash
Posted: Thu May 26, 2016 11:52 am
by face_off
Hi - how exactly are you loading the vbd pls? Can you post a screenshot of how you did this? Are you able to also post the vdb pls?
Posted: Thu May 26, 2016 12:12 pm
by Hesekiel2517
Hey Paul, sure:
Thank you for the fast reply!
Posted: Fri May 27, 2016 1:28 am
by face_off
I have found the issue - and it will be fixed in the next release. In the meantime, pls do not attempt to render vdb files in the plugin.
Posted: Fri Jun 17, 2016 9:42 am
by divljikunic
Confirming the bug, is this fixed yet?
So, you think it will be possible to render vdbs normally (meaning they get rendered as volumes, not converted to geometry) in the plugin?
That'd be great, I need "real" fire in the fireplace not some compositing tricks..
Posted: Fri Jun 17, 2016 9:44 am
by divljikunic
Oh, btw, ran into this, hopefully it might help.. So, basically there's a type of compression that vdb version 3 uses which is not supported by the modo importer, however vdbs without it load fine..
http://community.thefoundry.co.uk/discu ... 9&t=109419
Posted: Fri Jun 17, 2016 11:53 am
by face_off
Yes, fixed in the latest TEST release. Pls see
https://docs.otoy.com/manuals/products/ ... -features/ for details. You can also add an Octane Override to the Volume Item Group in the Shader Tree and attach a NodeGraph node to it with a Volume Medium. However it's alpha-quality functionality at the moment, and will work better in the next release (at which time I'll explain the workflow better in the manual).
