plugin problems and displacement (SOLVED)
Posted: Tue May 24, 2016 1:14 pm
by jelly
Hello, I'm encountering a problem after plugin installation:
1. I have installed the standalone
2. installed the c4d plugin (version 300-R1)
In the consolle Iread this error:
Scene Plugin is older than version 3.00-R1
Plugin will convert the parameters of displacement texture
Animated attributes should be changed manually!
I'm trying a displacement, but it does not displace.
Suggestions?
Re: plugin problems and displacement
Posted: Tue May 24, 2016 1:17 pm
by aoktar
It's normal message when you open a scene which is used older version of plugin. It makes some revisions for compatibility.
My suggestion is that post somethings to give more idea what you do.
Posted: Tue May 24, 2016 3:54 pm
by jelly
Thank you, it was an old scene, saved and re opened a new one and in works ok. I probably was making some mistake, it's fine now.
