Infinite mirror problem
Posted: Wed Feb 16, 2011 2:25 am
by Miguel Lescano
In this test with a mirror material from the online repository, reflections seem to stop somewhere around 20 bounces ans then go to a black blur... I made sure to set bounces to the maximum in the Pathtracing engine.
Any suggestions on how to achieve infinite mirror reflections? This is important for interior design.
Re: Infinite mirror problem
Posted: Wed Feb 16, 2011 5:10 am
by face
Maybe the lens aperture is set to high, so that the bounces are blurred?
face
Posted: Wed Feb 16, 2011 6:39 am
by steveps3
If you are using pathtracing then you have hit the maxdepth.
Posted: Wed Feb 16, 2011 3:09 pm
by Miguel Lescano
@face: Aperture is small... That's why the palm trees in the reflections are in focus.
@steveps3: Do you know if this is a limitation of the beta?
Posted: Wed Feb 16, 2011 3:29 pm
by matej
In reality how many times are "infinite" reflections really needed in interior design?
A slight camera move in your example will make them finite and renderer manageable.
Posted: Fri Feb 18, 2011 12:50 am
by abstrax
Miguel Lescano wrote:In this test with a mirror material from the online repository, reflections seem to stop somewhere around 20 bounces ans then go to a black blur... I made sure to set bounces to the maximum in the Pathtracing engine.
You can't at the moment (and very likely for quite a while). For performance reason we allow only a limited amount of bounces and even if you set the limit very high, the russian roulette mechanism will terminate paths before you reach that limit. You can force it to trace the rays for hundreds of bounces, but this will only increase noise and massively reduce performance. -> Not recommended at all. If you want to render artificial situations, a different renderer is probably a better choice.
Cheers,
Marcus
