Render View not matching with Save Frame
Posted: Wed May 18, 2016 9:00 pm
by Refracty
Hi Paul,
maybe I am doing something wrong but very often the Renders don't match with exact Safe Frame that is set in the Rhino options.
The Rhino resolution is set in the same dimensions as the Octane Render target but the renders don't match 100 %.
What wout be the correct workflow???
Thank you
Nando
Re: Render View not matching with Save Frame
Posted: Wed May 18, 2016 10:50 pm
by face_off
Nando - can you post a screenshot and a sample scene showing this problem pls?
Posted: Thu May 19, 2016 11:39 am
by Refracty
I will try to reproduce this, because I can not hand over the scene...
Will get back to you soon.
Thank you
Posted: Fri May 20, 2016 7:44 am
by Refracty
HI Paul,
this is an example of the viewport not matching Rhino's save frame.
The viewport should end with the corners of the cubes.
How can I fix this?
Kind Regards
Posted: Mon Jul 04, 2016 5:49 pm
by Refracty
Hi Paul,
is there a solution for this?
We are having trouble here.
When we rerender shots they are not matching perfectly.
Ciao
Nando
Posted: Tue Jul 05, 2016 12:24 am
by franchais
Yes my render views changes as well when I switch monitors. Is there a proper way to keep saved views locked or at a default resolution
Its been a problem everytime I switch pc on the same file.
Still not too sure on this work flow
Posted: Tue Jul 05, 2016 10:49 am
by face_off
I put a fix for this in 3.0.22.66. Is this still an issue in the latest release? If so - can you post a sample Rhino file which shows the problem pls.
