Octane for Softimage 1.03 RC1 [Obsolete]
Autodesk Softimage XSI (Developed by Face)
face
Gescort wrote:Hi, face!
All work, but render region stable crushed softimage.
Here it worked with 2015.
But i haven´t tested it to deep. It should use the resolution from the camera view and the cropping is inside Softimage.
face
http://vimeo.com/user2509578
face
face
Ah yes, there must be an error, will try to fix it.
Something with the resolution must be wrong.
face
Gescort
After changed parameters (octane imager) rendered not continue, but begins first. It's not interactive.
face
Gescort wrote:After changed parameters (octane imager) rendered not continue, but begins first. It's not interactive.
Will check it also, thanks for report.
face
face
I will take a look at the problems at evening, maybe i can also include the instances on which im working.
face
wireframex
face wrote: Ah, now i know it.
Have you installed the Microsoft Visual C++ 2015 Redistributable(X64)?
face
Thanks it works now
Phil
Main Computer:
Ryzen 3990X / 96Go Ram / 2 x RTX 3090
OS: Windows 11 x64 - NVidia Driver 560.70 - Octane Plugin Build 2023.1.3.141
Licensed: Softimage 2012 SP1 / Lightwave 2024.0.1 / Rhino 8.9
face
wireframex wrote:
Ah, now i know it.
face[/quote]
Thanks it works now
Phil[/quote]
Good, will add it to the start page.
face
wireframex
Face
- Quick Render preview crash SI
- Need to replace all the shader with new ones from the last update to make a preview of the old scene
- Thumbnail of Material manager is not working like your last demo (only diffuse is working here)
Phil
Main Computer:
face
wireframex wrote:Face
Phil
With which version of Softimage?
Have tested it with 2013, 2014 and 2015.
face
wireframex
2015 SP2
Main Computer:
Return to “Autodesk Softimage XSI”
