Hi, Raoul,
let's clear/polish some points.
"You suggest a netstor over a cubix.. in that theres more breathing space between the cards? any other reasons?"
both Netstor & Cubix have extra space as far as I know..Main reason why I've talked about Netstor..is because You getting the same for less..so I would rise the question why to get Cubix? (I know they have separate products. some software, etc. but it's not usefull for us) so, why to pay more for Cubix, Magma, One Stop, or any other solution..
"I've read a lot about OSX gpu limitations but theres lots of contradictions. Some say El capitan will run 4 external if they are the same card other say it won't.. "
as mentioned before, that mainly depends on OS version, drivers, cuda..& then a bit on thin air (sometimes it's very hard to know what is messed up, but it's MAC related..) I'll attached some pics bellow if You are interested in exact version we've made to work for eGPU with 4GPU box I've showed.
"But i take i do need to upgrade to el capitan as a basic requirement. ( was holding off for other software conflicts with this OS)."
if You need that flexibility for the software to work.. Just build a slave & do not worry anymore about Mac issues with hardware..-it's another layer of complexity & I doubt You need it.
"Do you have any experience with an exact setup for a classic mac pro that has proven to run 4 cards external.. + the one internal card. If so, would love to know the exact details so i can replicate? "
I've added printscreen & few shots of the rig. You can try to replicate something simillar or..use more expensive, but faster (You get what You pay) enclosure from let's say Netstor (or any other company if You willing to overpay =)
"I guess i'd like to stick to something i can plugin into the mac.. so i don't need to run another windows system,.. theres added software costs with that route. But will look down that route if i can find a reliable way to run 4 external gpus with a mac pro. "
it should be as ease as plug & play & it is on windows, but not on Macs, sorry to say.. You will msot likelly have some issues solve unless You're extremelly lucky.
So any options? As mentioned in previous reply, I would try to build eGPU but then switch to render node if that eGPU would not work. I guess You could sell backplate prety easy.
Render node costs in terms of software is not that much.. OEM licence of windows You can get for 20-30$ I guess & then..OctaneRender Standalone csots what 150-200$? So what are the other cost? quad core CPU will be around 200-300$, good AIO cooler ~100-150$, then 32GB of RAM, let's say DDR3 is around 150$ & motherboard.. with 4x 8lanes.. probably 200-300$ ..ou PSU let's say 300$ & case 100-200$ - I mean in total You're looking 1000-1500$ for complete system (including licences) & then simply pick GPUs of Your choise.
Then again, I'm not to say slaves does not have any downsides..comunication between slave & Your Mac, compared to eGPU solution is not nearly as fast..but if eGPU cause You might have more headache with compatability..
So in the end, none of these solutions are perfect, Raoul. I mean having eGPU has ups/downs, then slave as well..& it really depends what are Your preferences are.
" I wish there was a central and regularly updated database of what does and doesn't work. "
it's hard to maintain this type database..There's a lot of good information scatered in these forums for instance, but it's just crumbs..
I have this idea to update site & have specific section for GPUs (ins & outs about different cards on the market), other for eGPU solutions (from the shelf, DIY, Mac related, etc), then Complete systems (different routes You can take), Watercooling..-we'll see.
smicha wrote:Tom, Your knowledge on external (and not only) solutions is impressive.
Thanks Sebastian.
by the way we chose 4x GPUs in external enclosure 'cos we got good price for them (bought new 780 6GB for 320EU & it gives like ~80 in OctaneBench out of the box, up to 100 if OCed) from value perspective that was a good choise. We kept OC out of the way to make sure that stability is not influenced by that. Alternativelly You can stick with pair of 980Ti, to see if You can make them work on Your setup - those would give ~ 240 , maybe 250 together & prices are dropping (if nvidia is goign to realease anything new they will dive even more). Avoid new cards for now.. as it will take time for glitches to be cleaned out in drivers & Mac OS compatability to arrive..Amfeltecs backplate seem to be value oriented option as well, but keep in mind that 1x limitation.
