animated light intensity
Posted: Thu Mar 31, 2016 9:34 pm
by sohara20
Hi, I'm trying to animate a light emitter's intensity without having to do a full scene reload on each frame? Is this possible?
Shane
Re: animated light intensity
Posted: Thu Mar 31, 2016 9:54 pm
by sohara20
this is just a simple plane with octane object properties, emision enabled and a texture for the light color.
Posted: Thu Mar 31, 2016 10:00 pm
by sohara20
Found the solution. Using a emission material instead of object properties since those dont refresh like materials do, result is the same. Thanks anyways.
Posted: Fri Apr 01, 2016 8:16 am
by juanjgon
Yes, you are right. The object animated spare parameters are not updated while rendering in update mode. I will try to fix this problem at least for the light parameters in the next build.
Meanwhile as you have found, animate emission materials should work without problems.
Posted: Fri May 06, 2016 5:24 pm
by juanjgon
The next plugin build will have a new option in the ROP node to enable the update of some of the OBJ spare parameters while rendering in update mode, like the visibility options and the emission features.
