OctaneRender® for Maya® 2.24.2 - 7.23 Linux [OBSOLETE]
Posted: Mon Mar 14, 2016 10:10 pm
Otoy® is proud to announce the availability of a new version of OctaneRender™ for Maya®
Maya® Version Requirements
This release will work with Maya® Version 2016 64-bit on Linux operating systems.
Notes regarding features/functionality
OctaneRender™ for Maya® implements almost full functionality of OctaneRender™ standalone inside Maya®.
To run OctaneRender™ for Maya®, you need to also have an activated OctaneRender™ Standalone copy activated on the machine you wish to install the plugin onto.
You cannot purchase and use only the Maya plugin and use it without also owning an activated copy of OctaneRender™ Standalone on your machine.
HOW TO PURCHASE LICENSES
Go to our online shop here: http://render.otoy.com/shop/
If you do not own an OctaneRender™ Standalone Edition License yet:
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
If you already own one or more OctaneRender™ Standalone Edition licenses you want to pair the plugin with:
Purchase an "OctaneRender™ for Maya® Beta License" priced at 199€
You can also purchase a 3, 5 or 10 pack of OctaneRender™ for Maya® licenses, just like OctaneRender™ Standalone Edition packs.
OCTANELIVE
Just like OctaneRender™ Standalone, the Maya® plugin product also needs an additional OctaneLive license and be activated on a machine.
This has to be done in the plugin interface panel in Maya, and is covered in the included PDF manual.
It can only be done after an OctaneRender™ Standalone license is already activated on the machine in question.
CHANGES SINCE THE PREVIOUS VERSION
Installation:
- Just run the installer to see its command line keys.
DOWNLOAD
OctaneRender for Maya - v7.23 Linux
OctaneRender for Maya - v7.23 Linux DEMO
For network slave and daemon please download standalone installer here:
viewtopic.php?f=24&t=50498
Yours,
The OctaneRender™ Team.
OCTANELIVE
1. For Textures attribute power defaults to 1.0 now. (see viewtopic.php?f=111&t=53049)
2. Default pass names for composite EXR are set when the respective field in render settings is left empty. (see viewtopic.php?f=28&t=53067)
3. Suffix _passes (and for non composite EXR all seperate pass names _****) is/are added before the framenumber. (see viewtopic.php?f=110&t=53046)
Installation:
DOWNLOAD
Yours,
