batch rendering
Posted: Mon Mar 07, 2016 10:06 am
by Stassius
Hello! In new 3.00.6 version we can make batch render with multiple rop nodes. Howewer it doesn't work as expected in Houdini. When you create a bunch of rop nodes and merge them all in one merge node you can press "Render" only on merge node to render all the rops above. But now when you press Render on merge node, Octane renders only current frame when rops have "Frame range" specified, so you still have to manually render each node.
Re: batch rendering
Posted: Mon Mar 07, 2016 10:48 am
by juanjgon
Thanks for reporting. I will test this problem here.
Re: batch rendering
Posted: Mon Mar 07, 2016 10:55 am
by Stassius
Additional info. You can wire ROPs one by one to make an usual chain. In this case you can hit Render on last node and Octane batch renders all of them. However frame range not taken from each node - it takes it from only one of them. So every sequence is equal in frame range.
Re: batch rendering
Posted: Thu Mar 10, 2016 11:41 am
by juanjgon
I have found the problem. By default the render buttons render the multiple ROPs frame by frame, something that is impossible in Octane due to the ROP node architecture (you can't have more than one scene initialized at the same time).
The solution is easy: you can render multiple ROPs (in a chain or with the merge node) if you open the "Controls" panel, select the render order "Node by Node" and press "Render".
I hope this helps.
Re: batch rendering
Posted: Fri Mar 11, 2016 7:26 am
by Stassius
Yes, but it still doesn't respect frame ranges specified.
I had two ROPs - one for 75 frames, another for 125.
Both were rendered as 125 frames.
Re: batch rendering
Posted: Fri Mar 11, 2016 9:18 am
by juanjgon
You are right. I have fixed a problem perhaps related to this problem ... but anyway the main problem is that it seems a limitation of Houdini. I am testing a scene rendering two chained Mantra ROP nodes, one with a 5 frames range and other with 10 frames range, and both are rendered using the 10 frames range. If use the merge node I also get the same behavior.
Can you please check in your system if Mantra has the same problem, to be sure? I am testing H15.0.393
Re: batch rendering
Posted: Sat Mar 12, 2016 12:26 pm
by Stassius
Sorry, it was my mistake. When you set Frame Range to (Strict) on every ROP node and then set "Node by Node" in Merge, then everything renders correct.
Hooray, problem solved! Thank you!
Re: batch rendering
Posted: Sat Mar 12, 2016 4:54 pm
by juanjgon
Stassius wrote:Sorry, it was my mistake. When you set Frame Range to (Strict) on every ROP node and then set "Node by Node" in Merge, then everything renders correct.
Ahh, thanks. Yes, this is the correct workflow to render multiple ROP nodes.
