Watercooled 4x 980ti Octane Render Workstation - BLACK
Posted: Fri Mar 04, 2016 10:13 pm
- Phanteks Enthoo Primo BLACK
- Asus X99 E WS 3.1 BLACK
- 5930k + EK WB BLACK
- 4x 980ti EVGA + EK WB + backplates BLACK + quad bridge BLACK
- 64GB DDR4 2133, corsair 4x16GB BLACK
- 1600W EVGA T2 BLACK
- 2xD5 EK + dual top BLACK
- BP res 150 BLACK
- Aquaero 6 PRO ... oooops stainless steel
- 21 NB PL2 120mm fans with Phobya splitters BLACK
- SSD 500GB system + SSD 1TB working files + 6TB HDD storage WD BLACK
- Icy dock hot swap 3 HDDS BLACK
- EK rads 480 + 360 +240 BLACK
- Koolance fittings BLACK + EK ZMT BLACK 16/10 tubing + PB valve BLACK
MENU AiTweaker:
Ai Overclock Tuner: XMP
CPU strap: 100Mhz
PLL selection: LC PLL
BCLK freq.: 100
Asus multicore enhancement :disabled
Cpu core ration: sync all cores
1-core ratio limit 40 (for some mild OC)
Min and max cpu cache ratio: auto
Internal PLL overvoltage: Disabled
EPU power saving mode: Disabled
Submenu: external digi + power control:
CPU power phase control: extreme
CPU power duty control: extreme
CPU current capability: 130%
Submenu: internal CPU power man.:
enhanced intel speedstep techn.: Disabled
turbo mode: enabled
Back to Ai tweaker: CPU core volt. - my reads at above settings is 1.2V (tested for 3 days - stable), so one can input 1.2V or leave on auto - cpuz shows 1.2V constantly - some users report that for 4.5GHz 1.275V may be enough but this is dependent of how lucky you are on cpu quality.
CPU spread spectrum: disabled
MENU: advanced/cpu power manag. config.
enhanced intel...: disabled
turbo: enabled
c states : disabled
It's the fastest 4x980ti build - 570. With 7x980ti on Z10PE it might approach score 1000.
Temps 4x 980ti 24C at idle, 40C at OC 1500Mhz @ 1000RPMs of PL2; 2xD5 at 2200RPMs; 5930k @ 4Ghz @ 1.2V, 25-45C; power draw 800W
Octane score 515 stock, 570 OC BLACK
Some night shooting - Nikon D610, 50mm 1.8, tripod, ISO 100-200.
